Solved DataBase Example
Discussion in 'Call Flow Designer' started by agesen, May 29, 2017.
  1. agesen
    Oct 17, 2016
    18
    Anyone who can provide me with more information of the SQL database structure?
    An example for use with the PhoneSupportPortal Demo would be great.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,073
    75
    Hi @agesen,
    Did you check this article?
    https://www.3cx.com/docs/cfd-accessing-database/
    The database structure is whatever you define. Then you create the SQL query to access that specific database...
    Kind regards.
  3. agesen
    Oct 17, 2016
    18
    Yes I did check that article, but still facing problems.
    I have a MS SQL 2014 and created a Database named 'CustomersDatabase'
    In that I have a Table named 'customers' and a column named 'id'
    I have inserted 1 test PIN
    The sql syntax in the example "SELECT count(*) FROM customers WHERE id={0}" is returning a syntax error.
    What i'm missing here :)
  4. agesen
    Oct 17, 2016
    18
    Hi :)
    I found the problem - wrong configured colum type
    Everything works perfect :)
    jed likes this.
  5. edossantos
    Jun 27, 2007
    1,073
    75
    Excellent! Thanks for the feedback!
