Database Integrated Security
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Aug 29, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    When accessing a database through an integrated security connection string, which user will the system attempt to use? The user account for one of the 3cx windows services?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    If I recall, you have to setup your SQL Server for multimode authentication (Windows/Domain + SQL Server Auth) and/or create a DSN and specify it in the VAD program.
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    You can not create the connection string manually. For SQL Server you need to specify username, password, database name and server, and it uses SQL Server authentication. If you need to use Windows Integrated Authentication with SQL Server you can do it using ODBC, and configure the DSN to do it.
