- Joined
- Oct 24, 2014
- Messages
- 75
- Reaction score
- 1
Hi all,
I'm working on my first VAD project. We have several conference rooms, and management is worried about people being able to make expensive outside calls from those public spaces without knowing who did it. We would like to have a dialer that prompts them to enter an extension and the extension's PIN, check to make sure that they're valid, and then prompt the user for the number they want to call and dial the number.
I think I have all this set up, but I'm hitting an error of some sort, I think with the database lookup.
I am attaching pictures of the process. The UserLogin component prompts first for the Extension and then for the PIN, and both of those get input correctly (I can see the variables change when I step through a Debug call), but then as soon as it hits the ValidateData component the call dies. When I go through the Debug log one step at a time it goes through each step of the UserLogin component, and then when it jumps over to the ValidateData component, it jumps to the Error Handler Flow screen, which I presume means it's hitting some error. The "CurrentErrorName" variables changes to "error.semantic.ecmascript". Does this mean that my database lookup is wrong? Do I have the right setup for it to do an ODBC connection to the Postgres database?
Thanks.
Thanks.
