Database service crashing
Discussion in '3CX Phone System - General' started by Matounetti, Aug 28, 2009.
  1. Matounetti
    Aug 27, 2009
    I've got a problem with 3CX 7.1.
    It runs on :
    . Windows XP SP3 .NET 3.5 SP1
    . Cassini
    . The OS is a Virtual Machine powered by Virtual Server 2005 SP1 with 1Gb of memoy
    The installation was running well but we've got a problem since today : the 3CX phonesystem database service just stop after start.
    The only log i have in windows application logs is "log shutting down"
    I tried
    . to reboot the guest OS
    . reboot the services
    . wait for the others to load then start it
    The others services run well.
