DataBase
Discussion in '3CX Phone System - General' started by Nour, Feb 12, 2015.
  1. Nour
    Feb 9, 2015
    6
    Hi all
    How can I view the database that has all the information for the calls i did
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    I don't know that your desire of viewing a database is as simple as it might seem or not without some danger. If you want to see info about calls, the easy way is to simple use the reports feature and filter accordingly. If you want really detailed info which includes technical details, you should look at the 3CX Bin log viewer. Both methods are described in the blog.
