Date format on phones
Discussion in '3CX Phone System - General' started by techexperts33, Mar 13, 2014.
  1. techexperts33
    Nov 13, 2013
    5
    We're having a bit of trouble with the date format on our SNOM phones.
    I have the 3cx system set for US date format, ie, 3/13/2014
    If I change the date format directly on the phone, the next time the phone is provisioned, it reverts to the European date format, ie, 13/3/2014.
    Is there a permanent way to change this? Did I miss a setting somewhere in the PBX?
    thank you,
    Tom Fox
    11,119
    330
    The format would be set in the provisioning file.
    http://www.3cx.com/blog/docs/phone-provisioning-templates/
  3. techexperts33
    Nov 13, 2013
    5
    Thank you! I was able to modify the template to correct the date.
  4. 3cxBora
    Jun 17, 2015
    38
    Hi, where is the time and date format, section in the template.
    I like to display the time in 12 hours format instead of 24-hours.
    Thank you for your time and sharing,
    Bora
  5. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    You have to search for this line(s):
    <!--# The "time_24_format" field specifies whether to display the time in 24-hour format or in AM/PM format. Valid values are "on"==24-hour Format, "off"==AM/PM Format. The provisioning template sets the valut to "on"==24-Hour Format.-->
    <time_24_format perm="">on</time_24_format>
