dates in logs
Discussion in '3CX Phone System - General' started by oliverm, Jan 26, 2012.
  1. oliverm
    Mar 10, 2009
    79
    Is there anyway to find the date in the 3cxphonesystem.log file? It's quite big and seems to only record the times against each entry and not the date.
    If not, is there some way we can get the date put in? Some setting somewhere. Seems like an odd oversight.
    Olly
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Activate in Settings, Advanced pannel, "keep backup of log file". You will find in "C:\ProgramData\3CX\Data\Logs\Backup" folders named by date. In those folders you will find "3cxphonesystem.log" for every day.
    Be aware that this action can consume a lot of disk space. You should delete them from time to time.
