Day of Week
Discussion in 'Call Flow Designer' started by Eric Osborn, Jun 13, 2017.
  1. Eric Osborn
    Mar 24, 2017
    27
    Does someone know how to route based on day of week?
    I'm looking to do the following---
    Monday through Thursday from 9am to 5pm route to location A
    Friday 9am to 8pm route to location B
    Saturday and Sunday from 12pm to 8pm route to location C
    Thank you!
    Eric
  2. DL_
    DL_
    Mar 31, 2015
    55
    8
  3. Eric Osborn
    Mar 24, 2017
    27
    Hey thank you for those.... From what I understand in other post he is using new Date().getDay() == 0 which should be for Sunday?
    When I compile, I get the namespace "Date" could not be found. Tried couple other ways using Microsoft article but not getting it. Time of day I think I'm good with.
    Eric
  4. DL_
    DL_
    Mar 31, 2015
    55
    8
    Wrong language. You need to use C# in the CFD.
    You can use an integer compare (i.e. 0 = Sunday) but you should also be able to use the constants as below to make it more readable.
    DateTime.Now.DayOfWeek == DayOfWeek.Sunday
    You can also use other operators such as
    DateTime.Now.DayOfWeek >= DayOfWeek.Monday && DateTime.Now.DayOfWeek <= DayOfWeek.Friday
    Just remember that Sunday is the lowest day and Saturday is the highest
    Test it (and other C# code) here: https://dotnetfiddle.net/7ghv7A
    #4 DL_, Jun 14, 2017
  5. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,367
    110
    Hi Eric,
    The articles that mention this:
    Are referring to the old VAD for v14, which uses Javascript. In the CFD for v15 you can't use Javascript, and that's why you're getting that error. You need to use C# instead, as very well explained by @DL_.
    Kind regards.
  6. Eric Osborn
    Mar 24, 2017
    27
    Thank you and DL thank for that outline! I will try this out today.
  7. Eric Osborn
    Mar 24, 2017
    27
    @dl @edossantos , Hey,
    Could you tell me if I wrote this right? I'm not getting it to work correctly. We open at 11am daily, close at midnight Sunday through Thursday and 2am on Friday and Saturday nights.
    ((DateTime.Now.Hour >= 9 && DateTime.Now.Hour <= 24) || (DateTime.Now.DayOfWeek == DayOfWeek.Saturday && DateTime.Now.Hour <2) || (DateTime.Now.DayOfWeek == DayOfWeek.Sunday && DateTime.Now.Hour <2))
    Thanks for your help!
  8. edossantos
    Jun 27, 2007
    1,367
    110
    Hi @Eric Osborn,
    The expression looks good to me. I would just change:
    to:
    DateTime.Now.Hour < 24
    Because the hour will never be 24. But anyway that will not cause a bug...
    So this is not working for you? What problem are you experiencing?
    Kind regards.
