DDI display
Discussion in '3CX Phone System - General' started by bigsiqc, Jun 10, 2009.
  1. bigsiqc
    Nov 21, 2007
    23
    I employ a partially sighted receptionist who can see things on a computer screen if they are very large.
    I have set up ddi lines so that they attach the company name to the callerid and this displays on the phones. Does anyone know if there is any software that would take this numer and ddi line info and display it on a cuputer screen? Call assistant doesn't seem to do this and using a softphone the display is too small.
    Any ideas.
    thanks
    Simon
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello,
    idiot question.
    do you test to change resolution of screen ?
    for software you can search tapi software.
    regards
  3. bigsiqc
    Nov 21, 2007
    23
    Thanks for the Tapi hint.
    The screen resolution is irrelevant as the characters have to be at least 10 cm high for her to read them!
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    i don't know if it's you have need but look this
    http://www.freedownloadscenter.com/Programming/ActiveX/Caller_ID_ActiveX__OCX__Screenshot.html
    it's write in big character.
  5. bigsiqc
    Nov 21, 2007
    23
    merci beaucoup... just what I was after
