DDNS problems
Discussion in 'Android' started by marc.palmer, Aug 24, 2010.
  1. marc.palmer
    Jun 30, 2010
    6
    I am having trouble with using ddns with my 3cx for android. When I use my dynamic ip
    address (xx.xx.xx.xx) everything works perfectly. Changing it to my ddns
    name (goldstar.xx.com) the android registers and receives calls, but does not make calls.
    It just goes back to 'available' when I attempt to call out. I also do not see anything
    in the 3cx log. Does this make any sense?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hi,
    on your firewall / router you have redirected port from any source and not only xxx.xxx.xxx.xxx ?
  3. marc.palmer
    Jun 30, 2010
    6
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    we can suppose dns error no ?maybe try to ping you dyndns address.
  5. marc.palmer
    Jun 30, 2010
    6
    As I stated, it registers and receives call using the ddns name. So the ddns is resolving the ip address or it would not even register. The only it does not do is place calls, which it does just fine if the numbered ip address is used instead.
