- Joined
- Dec 3, 2015
- Messages
- 13
- Reaction score
- 0
I'm new to 3CX and we've just setup our server. I am trying to get the fax to email to work and have not been getting it to work.
What we are seeing is the fax extension is not ringing and picking up. When I dial the DID attached to the fax extension it is just dead air. I assume I should hear the fax tone...
We are running 3cx 14. I've setup a Fax extension under the Fax section as extension 8888. It is setup to inbound route the DID 6419876543 to "send fax to email extension 8888" .
What am I missing?
Here is some information from the activity logs
16-Feb-2016 10:24:14.651 NAT/ALG check:L:953.1[Line:10000<<17151234567] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:14.523 NAT/ALG check:L:953.2[Fax] REQUEST 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:12.950 NAT/ALG check:L:953.1[Line:10000<<17151234567] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:12.819 NAT/ALG check:L:953.2[Fax] REQUEST 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:11.307 NAT/ALG check:L:953.1[Line:10000<<17151234567] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:11.004 NAT/ALG check:L:953.2[Fax] REQUEST 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:09.516 [CM503007]: Call(C:953): Fax:8888 has joined, contact <sip:[email protected]:5006>
16-Feb-2016 10:24:09.512 [CM503007]: Call(C:953): Line:10000<<17151234567 has joined, contact <sip:[email protected]:5060>
16-Feb-2016 10:24:09.510 L:953.2[Fax] has joined to L:953.1[Line:10000<<17151234567]
16-Feb-2016 10:24:09.510 NAT/ALG check:L:953.2[Fax] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:09.453 [CM503025]: Call(C:953): Calling T:Fax:8888@[Dev:sip:[email protected]:5006;user=phone] for L:953.1[Line:10000<<17151234567]
16-Feb-2016 10:24:09.412 [CM503027]: Call(C:953): From: Line:10000<<17151234567 ("+17151234567" <sip:[email protected]:5060>) to T:Fax:8888@[Dev:sip:[email protected]:5006;user=phone]
16-Feb-2016 10:24:09.412 [CM503004]: Call(C:953): Route 1: from L:953.1[Line:10000<<17151234567] to T:Fax:8888@[Dev:sip:[email protected]:5006;user=phone]
16-Feb-2016 10:24:09.412 [CM505003]: Provider:[Sangoma-SBC] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NetBorder Session Controller] PBX contact: [sip:[email protected]:5060]
16-Feb-2016 10:24:09.410 [CM503001]: Call(C:953): Incoming call from Line:10000<<17151234567 to <sip:[email protected]:5060>
16-Feb-2016 10:24:09.410 Line limit check: Current # of calls for line Lc:10000(@Sangoma-SBC[<sip:[email protected]:5060>]) is 1; limit is 15
16-Feb-2016 10:24:09.410 NAT/ALG check:L:953.1[Line:10000<<17151234567] REQUEST 'INVITE' - basic check passed. No information for extended checks
16-Feb-2016 10:24:09.406 [MS006000] C:953.1: connection address is enforced to 10.91.15.10
16-Feb-2016 10:24:09.399 [CM503012]: Inbound any hours rule (flowroute main 2231) for 10000 forwards to Fax:8888
16-Feb-2016 10:23:44.678 Leg L:952.2[Line:10000>>17635775789] is terminated: Cause: BYE from PBX
16-Feb-2016 10:23:44.677 [CM503008]: Call(C:952): Call is terminated
What am I missing?
