Dealy to start the message
Discussion in '3CX Phone System - General' started by flaviost, Aug 27, 2007.
  1. flaviost
    Aug 17, 2007
    18
    Why some times take so long time to begin the message after the system answer the call?
    It usually happens. Some timee I call my system to check if everything is working well, and take from 6 to 8 seconds after asnwer to start to play the message of the first Digital Receptionist.
    Exist any way to improve it?"
  2. gbarnes
    Aug 3, 2007
    83
    improve
    Please could you turn logging to verbose and replicate the call, then send in the log?
    Do you have a slow system? How much ram?
    Does it seem to be accessing disk a lot when it answers?
    Or could your .wav file simply have a bit of silence before it..
    Moving on from there what equipment are you using, gateway or voip provider?
    Has anyone else had this problem and fixed it I wonder?
    Graeme.
  3. gbarnes
    Aug 3, 2007
    83
    Logs
    Actually the logs would probably tell whats going on.
    I have tryed to access my DR while opening a large file at the same time and it does increase by 3-4 secs or so.
    Ill await them and have a look.
    Graeme.
  4. todd
    Jun 9, 2007
    35
    Same problem
    Dear gbarnes,
    I got same problem with my system.
    verbose log:
    01:43:33.296 StratInOut::eek:nHangUp [CM104007] Call(2): Call from Ln:10000@engin 9.95 to 4000 has been terminated by Ln:10000@engin 9.95; cause: BYE; from IP:203.161.160.69
    01:43:22.015 CallLegImpl::eek:nConnected [CM103001] Call(2): Created audio channel for Ln:10000@engin 9.95 (203.161.160.79:20366) with Media Server (60.241.248.251:24799)
    01:43:21.937 CallConf::eek:nIncoming [CM103002] Call(2): Incoming call from 0731390275 (Ln:10000@engin 9.95) to sip:0733331518@voice.mibroadband.com.au
    My system is: HP ML G2 Server, 2 of Intel Xeon 3.0 Ghz CPU 2.0GB ram, running Windows 2003 Enterprise SP2, and only 3CX and Symantec AntiVirus software running.
    Looks not, the Disks are SATA Host RAID with 250GB each HDD.
    No, the wav file no silence before it. I cut all silence.
    I using SPA2000, SPA3000, GrandStream IP phones. Engin (Australian Voip provider) , if I use SPA2000 setup to Voip provider Account, It’s working fine.
  5. flaviost
    Aug 17, 2007
    18
    Sorry but I don't know how to get the verbose log.
    Any way I think that the problem could be RAM memory that I would like to update. If it should be a solution I will buy some Gbytes.
    But looking the tood problem we can check that the delays is happening, because he has a machine working only with the 3CX, crazy and it is not a bad machine.
    Some one can tell how much is the minimum system configuration to run the 3CX in an acceptable performance.
  6. gbarnes
    Aug 3, 2007
    83
    More
    So your 2000 when configured direct to SIP provider does not have the delay, but when configured through 3cx it does?
    How long is the delay?
    When Manage pstn --> PBX delevers audio is unset does this change anything?
    It cant be a jitter setting, because that would affect your sip direct link.
    Itfarmer, could you put your hardware expertise towards this please, its getting me. :roll: Does it always delay or intermittent?
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Re: Same problem
    Good information. We will try to investigate it.
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    It seems the delay is happening, at least it described here, but we still don't have any useful information to investigate a problem.
    todd just described his system, and I'm agree that his system is cool enough to handle 3CX PBX.
    Anybody, who has a problem with "long delay in case of 'bla-bla-bla'", could you please provide any (even trial) information that is related to your system?
    P.S. log level can be set on "General Settings" page.
  9. masterkiwi
    Apr 5, 2013
    Hi there,
    I have the same problem, you can resolve it by installing ping plotter to ping every 5 minutes or so to your pbx. that way it keeps it fresh.
    However the next problem i have is that it takes a very long time for the IVR to forward to an extension (or anything)..
    example: (ivr)welcome to us. press 1 for me ---TAKES LONGG---> (ivr)you'll be transfered to me --> (ext)music and forwarding to mobile.
    Here's my verbose:
    Code:
    05-apr-2013 12:00:31.789	L:27.3[Line:10000>>31612412526]: Terminating targets, reason:
    05-apr-2013 12:00:31.789	Leg L:27.3[Line:10000>>31612412526] is terminated: Cause: BYE from PBX
    05-apr-2013 12:00:31.789	Terminated from <sip:31612412526@sip3.nowhere.nl:5060>;tag=4RHUD51EWY30000E1D01006l00Z47EQ1QU0CD5 to "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;tag=466a2119; reason: LocalBye
    05-apr-2013 12:00:31.789	L:27.3[Line:10000>>31612412526] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=0f1e6f7efb6e565b Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			BYE sip:31.276.32.18:5060 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-0f1e6f7efb6e565b-1---d8754z-;rport
    			Max-Forwards: 70
    			Route: <sip:89.146.10.230;lr;ftag=466a2119;did=4dc.eb3dfa27>
    			Contact: <sip:sip3wvp00420@187.132.114.36:5060>
    			To: <sip:31612412526@sip3.nowhere.nl:5060>;tag=4RHUD51EWY30000E1D01006l00Z47EQ1QU0CD5
    			From: "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;tag=466a2119
    			Call-ID: YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.
    			CSeq: 3 BYE
    			Content-Length: 0
    05-apr-2013 12:00:31.789	SendMsg from "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;tag=466a2119 to <sip:31612412526@sip3.nowhere.nl:5060>;tag=4RHUD51EWY30000E1D01006l00Z47EQ1QU0CD5
    05-apr-2013 12:00:31.788	[CM503008]: Call(C:27): Call is terminated
    05-apr-2013 12:00:31.788	L:27.3[Line:10000>>31612412526]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
    05-apr-2013 12:00:31.783	Blocking refers for the Call(C:27)
    05-apr-2013 12:00:31.783	Call(C:27) is terminated
    05-apr-2013 12:00:31.782	L:27.1[Line:10000<<0523610878]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    05-apr-2013 12:00:31.782	Leg L:27.1[Line:10000<<0523610878] is terminated: Cause: BYE from 89.146.10.230:5060
    05-apr-2013 12:00:31.777	L:27.1[Line:10000<<0523610878] got Terminated Recv Req BYE from 89.146.10.230:5060 tid=4e32.4ce8d5c3.0 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			BYE sip:sip3wvp00420@187.132.114.36:5060 SIP/2.0
    			Via: SIP/2.0/UDP 89.146.10.230:5060;branch=z9hG4bK4e32.4ce8d5c3.0
    			Via: SIP/2.0/UDP 31.276.32.22:5060;received=31.276.32.22;rport=5060;branch=z9hG4bK-6fba-1365156019-3143-173
    			Max-Forwards: 69
    			Record-Route: <sip:89.146.10.230;lr;ftag=95ffcd055e0f78f7d5d397020e89288dd6f599e5>
    			To: <sip:315230784044@89.146.10.230:5060>;tag=7613b128
    			From: <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5
    			Call-ID: 5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22
    			CSeq: 2 BYE
    			Reason: Q.850 ;cause=16 ;text="Normal call clearing"
    			Content-Length: 0
    05-apr-2013 12:00:31.777	Terminated from <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5 to <sip:315230784044@89.146.10.230:5060>;tag=7613b128; reason: RemoteBye
    05-apr-2013 12:00:31.777	L:27.1[Line:10000<<0523610878] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=4e32.4ce8d5c3.0 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			SIP/2.0 200 OK
    			CSeq: 2 BYE
    			Content-Length: 0
    05-apr-2013 12:00:31.777	SendMsg from <sip:315230784044@89.146.10.230:5060>;tag=7613b128 to <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5
    05-apr-2013 12:00:26.744	L:27.2[Ivr]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    05-apr-2013 12:00:26.744	Leg L:27.2[Ivr] is terminated: Cause: BYE from 127.0.0.1:40600
    05-apr-2013 12:00:26.740	L:27.2[Ivr] got Terminated Recv Req BYE from 127.0.0.1:40600 tid=29229f138c0ed904 Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			BYE sip:0523610878@127.0.0.1:5060 SIP/2.0
    			Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-29229f138c0ed904-1---d8754z-;rport=40600
    			Max-Forwards: 70
    			Contact: <sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27>
    			To: <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a
    			Call-ID: YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.
    			CSeq: 5 BYE
    			User-Agent: 3CX IVR
    			Reason: SIP;description="User Hung Up"
    			Content-Length: 0
    05-apr-2013 12:00:26.740	Terminated from <sip:800@127.0.0.1:5060>;tag=d227a531 to <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a; reason: RemoteBye
    05-apr-2013 12:00:26.740	L:27.2[Ivr] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=29229f138c0ed904 Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			SIP/2.0 200 OK
    			Contact: <sip:0523610878@127.0.0.1:5060>
    			CSeq: 5 BYE
    			Content-Length: 0
    05-apr-2013 12:00:26.739	SendMsg from <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a to <sip:800@127.0.0.1:5060>;tag=d227a531
    05-apr-2013 12:00:26.563	FilePlayEndEventHandler
    05-apr-2013 12:00:26.551	[CM503007]: Call(C:27): Line:10000>>31612412526 has joined, contact <sip:sip3wvp00420@sip3.nowhere.nl:5060>
    05-apr-2013 12:00:26.537	~Target=VoIPline:31612412526@(Ln.10000@nowhere.Comm)
    05-apr-2013 12:00:26.537	L:27.1[Line:10000<<0523610878]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
    05-apr-2013 12:00:26.537	~Route=Dev:sip:sip3wvp00420@sip3.nowhere.nl:5060
    05-apr-2013 12:00:26.537	L:27.3[Line:10000>>31612412526] has joined to L:27.1[Line:10000<<0523610878]
    05-apr-2013 12:00:26.537	Session 43121 of leg L:27.3[Line:10000>>31612412526] is connected
    05-apr-2013 12:00:26.537	L:27.3[Line:10000>>31612412526] got Connected.UAC Recv 200/INVITE from 89.146.10.230:5060 tid=0a48f05cbb62cd26 Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			SIP/2.0 200 Ok
    			Via: SIP/2.0/UDP 192.168.1.8:5060;received=187.132.114.36;branch=z9hG4bK-d8754z-0a48f05cbb62cd26-1---d8754z-;rport=5060
    			Record-Route: <sip:89.146.10.230;lr;ftag=466a2119;did=4dc.eb3dfa27>
    			Contact: <sip:31.276.32.18:5060>
    			CSeq: 2 INVITE
    			Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, PRACK, INFO, REFER, NOTIFY, SUBSCRIBE, UPDATE
    			Content-Type: application/sdp
    			Supported: timer, replaces, from-change, x-diversion
    			Allow-Events: refer
    			P-Asserted-Identity: <sip:0612412526@sip3.nowhere.nl>
    			Content-Length: 229
    			v=0
    			o=- 1547671413798960455 1 IN IP4 31.276.32.18
    			s=-
    			c=IN IP4 31.276.32.34
    			t=0 0
    			m=audio 35540 RTP/AVP 0 101
    			a=rtpmap:0 PCMU/8000
    			a=rtpmap:101 telephone-event/8000
    			a=fmtp:101 0-15
    			a=ptime:20
    			a=silenceSupp:off - - - -
    05-apr-2013 12:00:26.537	Connected(UAC) from <sip:31612412526@sip3.nowhere.nl:5060>;tag=4RHUD51EWY30000E1D01006l00Z47EQ1QU0CD5 to "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;tag=466a2119
    05-apr-2013 12:00:26.537	Remote SDP is set for leg L:27.3[Line:10000>>31612412526]
    05-apr-2013 12:00:26.537	Answer SDP arrived on Leg L:27.3[Line:10000>>31612412526];
    OnAnswer Recv 200/INVITE from 89.146.10.230:5060 tid=0a48f05cbb62cd26 Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			SIP/2.0 200 Ok
    			CSeq: 2 INVITE
    			Allow-Events: refer
    			Content-Length: 229
    			v=0
    			s=-
    			t=0 0
    			a=fmtp:101 0-15
    			a=ptime:20
    05-apr-2013 12:00:26.537	[CM505003]: Provider:[nowhere.Comm] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:sip3wvp00420@187.132.114.36:5060]
    05-apr-2013 12:00:26.537	[CM503002]: Call(C:27): Alerting Line:10000>>31612412526 by contact <sip:sip3wvp00420@sip3.nowhere.nl:5060>
    05-apr-2013 12:00:26.529	UacSession 43121 has formed leg L:27.3[Line:10000>>31612412526]
    05-apr-2013 12:00:26.529	Answer from <sip:31612412526@sip3.nowhere.nl:5060>;tag=4RHUD51EWY30000E1D01006l00Z47EQ1QU0CD5 to "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;tag=466a2119
    05-apr-2013 12:00:26.529	L:27.3[Line:10000>>31612412526] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=d21f262ce84c9509 Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			ACK sip:31.276.32.18:5060 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-d21f262ce84c9509-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 2 ACK
    			Proxy-Authorization: Digest username="sip3wvp00420",realm="sip3.nowhere.nl",nonce="515ea0b400008f00526bd05e9525d54050bd52b33fd520fc",uri="sip:31612412526@sip3.nowhere.nl:5060",response="7346d2b7f3f994a3a9ca05e5c66e6995",algorithm=MD5
    			Content-Length: 0
    05-apr-2013 12:00:26.529	SendMsg from "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;tag=466a2119 to <sip:31612412526@sip3.nowhere.nl:5060>;tag=4RHUD51EWY30000E1D01006l00Z47EQ1QU0CD5
    05-apr-2013 12:00:26.233	Currently active calls - 1: [27]
    05-apr-2013 12:00:22.943	Provisional response (malformed) arrived to Leg L:27.3[Line:10000>>31612412526]
    05-apr-2013 12:00:22.943	L:27.3[Line:10000>>31612412526] got Provisional Recv 183/INVITE from 89.146.10.230:5060 tid=0a48f05cbb62cd26 Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			SIP/2.0 183 Session Progress
    			CSeq: 2 INVITE
    			Content-Length: 229
    			v=0
    			s=-
    			t=0 0
    			a=fmtp:101 0-15
    			a=ptime:20
    05-apr-2013 12:00:22.943	Provisional(183) malformed
    05-apr-2013 12:00:22.829	Provisional response (malformed) arrived to Leg L:27.3[Line:10000>>31612412526]
    05-apr-2013 12:00:22.829	L:27.3[Line:10000>>31612412526] got Provisional Recv 183/INVITE from 89.146.10.230:5060 tid=0a48f05cbb62cd26 Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			CSeq: 2 INVITE
    			Supported: x-diversion
    			Content-Length: 229
    			v=0
    			s=-
    			t=0 0
    			a=fmtp:101 0-15
    			a=ptime:20
    05-apr-2013 12:00:22.829	Provisional(183) malformed
    05-apr-2013 12:00:18.220	Provisional response (malformed) arrived to Leg L:27.3[Line:10000>>31612412526]
    05-apr-2013 12:00:18.220	L:27.3[Line:10000>>31612412526] got Provisional Recv 180/INVITE from 89.146.10.230:5060 tid=0a48f05cbb62cd26 Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			SIP/2.0 180 Ringing
    			To: <sip:31612412526@sip3.nowhere.nl:5060>;tag=c8598deb78957a18ce3b310bd9f5d802.1b3b
    			CSeq: 2 INVITE
    			Content-Length: 0
    05-apr-2013 12:00:18.220	Provisional(180) malformed
    05-apr-2013 12:00:18.161	[CM503025]: Call(C:27): Calling T:Line:10000>>31612412526@[Dev:sip:sip3wvp00420@sip3.nowhere.nl:5060] for L:27.1[Line:10000<<0523610878]
    05-apr-2013 12:00:18.161	Route to L:27.3[Line:10000>>31612412526] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=cf718717c91c653a Call-ID=YWRjOTI0ODNhNWQ3NDVkM2MwOGIwNDk2N2FjY2U1ZjI.:
    			INVITE sip:31612412526@sip3.nowhere.nl:5060 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-cf718717c91c653a-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 INVITE
    			Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    			Supported: replaces
    			Content-Length: 234
    			Remote-Party-ID: "315230784044"<sip:315230784044@sip3.nowhere.nl:5060>;party=calling
    			v=0
    			o=3cxPS 125392912384 42278584321 IN IP4 187.132.114.36
    			s=3cxPS Audio call
    			c=IN IP4 187.132.114.36
    			t=0 0
    			m=audio 9026 RTP/AVP 0 8 101
    			a=rtpmap:8 PCMA/8000
    			a=sendrecv
    05-apr-2013 12:00:18.161	Dev(1):[sip:sip3wvp00420@sip3.nowhere.nl:5060 / sip3wvp00420]: PBX contact is public IP: <sip:sip3wvp00420@187.132.114.36:5060>
    05-apr-2013 12:00:18.148	Outbound URI is used: sip:89.146.10.230;lr;ftag=95ffcd055e0f78f7d5d397020e89288dd6f599e5;did=0b3.bda59fd4
    05-apr-2013 12:00:18.148	Added leg L:27.3[Line:10000>>31612412526]
    05-apr-2013 12:00:18.099	[Flow] Call(C:27): making call from L:27.1[Line:10000<<0523610878] to T:Line:10000>>31612412526@[Dev:sip:sip3wvp00420@sip3.nowhere.nl:5060]
    05-apr-2013 12:00:18.099	[CM503027]: Call(C:27): From: Line:10000<<0523610878 (<sip:0523610878@192.168.1.8:5060>)  to  T:Line:10000>>31612412526@[Dev:sip:sip3wvp00420@sip3.nowhere.nl:5060]
    05-apr-2013 12:00:18.099	[CM503004]: Call(C:27): Route 1: from L:27.1[Line:10000<<0523610878] to T:Line:10000>>31612412526@[Dev:sip:sip3wvp00420@sip3.nowhere.nl:5060]
    05-apr-2013 12:00:18.099	Line limit check: Current # of calls for line Lc:10000(@nowhere.Comm[<sip:sip3wvp00420@sip3.nowhere.nl:5060>]) is 1; limit is 2
    05-apr-2013 12:00:18.099	Leg L:27.1[Line:10000<<0523610878]: Refreshing OutCID from endpoint Extn:200 = []
    05-apr-2013 12:00:18.099	[Flow] Call(C:27):  applied forwarding rule (Fwd[Custom 2/AllCalls]) Extn:200 -> Out#:>>Rule{Rule for nowhere.Comm}>>31612412526
    05-apr-2013 12:00:18.099	[Flow] Target endpoint for 31612412526 is Out#:>>Rule{Rule for nowhere.Comm}>>31612412526
    05-apr-2013 12:00:18.098	Selected prefix: 31
    05-apr-2013 12:00:18.098	Looking for outbound rule: dialed = [31612412526], processed: [31612412526]; from-ext: 200
    05-apr-2013 12:00:18.098	[Flow] Building target endpoint to 31612412526 from <sip:0523610878@192.168.1.8:5060> on behalf of 200
    05-apr-2013 12:00:18.098	[Flow] Target endpoint for 31612412526 is Out#:>>Rule{Rule for nowhere.Comm}>>31612412526
    05-apr-2013 12:00:18.098	[Flow] Call(C:27): has built target endpoint: Extn:200 for call from L:27.1[Line:10000<<0523610878]
    05-apr-2013 12:00:18.098	[Flow] Target endpoint for 200 is Extn:200
    05-apr-2013 12:00:18.098	[Flow] Building target endpoint to 200 from <sip:0523610878@192.168.1.8:5060>
    05-apr-2013 12:00:18.098	[CM503010]: Call(C:27): Making route(s) from Line:10000<<0523610878 to <sip:200@127.0.0.1:5060>
    05-apr-2013 12:00:18.098	[CM505003]: Provider:[nowhere.Comm] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:sip3wvp00420@187.132.114.36:5060]
    05-apr-2013 12:00:18.098	L:27.1[Line:10000<<0523610878]:  Updated OutCID: '315230784044' and DNName: ''
    05-apr-2013 12:00:18.098	Call(C:27): Referred(i): src=<sip:0523610878@192.168.1.8:5060;nf=e>; dst=<sip:800@192.168.1.8:5060>
    05-apr-2013 12:00:18.098	[Flow] Refer: RefTo=<sip:200@127.0.0.1:5060>; was call from=<sip:800@127.0.0.1:5060> to=<sip:0523610878@127.0.0.1:5060>
    05-apr-2013 12:00:18.098	Call transfer requested on Leg L:27.2[Ivr];
    Refer Recv Req REFER from 127.0.0.1:40600 tid=c4403f0d660ed766 Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			REFER sip:0523610878@127.0.0.1:5060 SIP/2.0
    			Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-c4403f0d660ed766-1---d8754z-;rport=40600
    			Max-Forwards: 70
    			CSeq: 3 REFER
    			User-Agent: 3CX IVR
    			Refer-To: <sip:200@127.0.0.1:5060>
    			Referred-By: <sip:800@127.0.0.1:5060>
    			Content-Length: 0
    05-apr-2013 12:00:18.098	Refer from <sip:800@127.0.0.1:5060>;tag=d227a531 to <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a
    05-apr-2013 12:00:17.894	L:27.2[Ivr] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=fe00d63365512c39 Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-fe00d63365512c39-1---d8754z-;rport=40600
    			CSeq: 2 INVITE
    			Supported: replaces
    			Content-Length: 351
    			v=0
    			o=3cxPS 203557961728 136650424322 IN IP4 127.0.0.1
    			s=3cxPS Audio call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			m=audio 7050 RTP/AVP 0 8 3 13 9 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=rtpmap:9 G722/8000
    			a=rtpmap:110 iLBC/8000
    			a=rtpmap:99 SPEEX/8000
    			a=recvonly
    05-apr-2013 12:00:17.894	SendMsg from <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a to <sip:800@127.0.0.1:5060>;tag=d227a531
    05-apr-2013 12:00:17.890	Answer to offerer immediateily, other party (L:27.1[Line:10000<<0523610878]) doesn't support re-invite
    05-apr-2013 12:00:17.890	Reneg. from L:27.2[Ivr], offer
    05-apr-2013 12:00:17.890	Leg L:27.2[Ivr] raised event RecvdRemoteSdp
    05-apr-2013 12:00:17.890	Remote SDP is set for leg L:27.2[Ivr]
    05-apr-2013 12:00:17.890	Offer SDP arrived on Leg L:27.2[Ivr];
    OnOffer Recv Req INVITE from 127.0.0.1:40600 tid=fe00d63365512c39 Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			INVITE sip:0523610878@127.0.0.1:5060 SIP/2.0
    			Max-Forwards: 70
    			CSeq: 2 INVITE
    			Supported: replaces
    			User-Agent: 3CX IVR
    			Content-Length: 360
    			v=0
    			o=3cxVCE 283021470 255282256 IN IP4 127.0.0.1
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			m=audio 40654 RTP/AVP 0 8 3 13 9 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=ptime:20
    			a=sendonly
    05-apr-2013 11:59:59.772	Session 43102 of leg L:27.1[Line:10000<<0523610878] is confirmed
    05-apr-2013 11:59:59.772	L:27.1[Line:10000<<0523610878] got Confirmed Recv Req ACK from 89.146.10.230:5060 tid=7e32.f7c19841.2 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			ACK sip:sip3wvp00420@187.132.114.36:5060 SIP/2.0
    			Via: SIP/2.0/UDP 89.146.10.230:5060;branch=z9hG4bK7e32.f7c19841.2
    			Via: SIP/2.0/UDP 31.276.32.22:5060;received=31.276.32.22;rport=5060;branch=z9hG4bK-a76-1365155987-3143-173
    			Max-Forwards: 69
    			CSeq: 1 ACK
    			Content-Length: 0
    05-apr-2013 11:59:59.772	ConnCfmd from <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5 to <sip:315230784044@89.146.10.230:5060>;tag=7613b128
    05-apr-2013 11:59:59.673	[CM503007]: Call(C:27): Ivr:800 has joined, contact <sip:800@127.0.0.1:40600>
    05-apr-2013 11:59:59.666	[CM503007]: Call(C:27): Line:10000<<0523610878 has joined, contact <sip:sip3wvp00420@sip3.nowhere.nl:5060>
    05-apr-2013 11:59:59.665	Session 43102 of leg L:27.1[Line:10000<<0523610878] is connected
    05-apr-2013 11:59:59.665	L:27.1[Line:10000<<0523610878] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=7e32.f7c19841.0 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 89.146.10.230:5060;branch=z9hG4bK7e32.f7c19841.0
    			Via: SIP/2.0/UDP 31.276.32.22:5060;received=31.276.32.22;rport=5060;branch=z9hG4bK-456a-1365155987-3143-173
    			Record-Route: <sip:89.146.10.230;lr;ftag=95ffcd055e0f78f7d5d397020e89288dd6f599e5;did=0b3.bda59fd4>
    			CSeq: 1 INVITE
    			Supported: replaces
    			User-Agent: 3CXPhoneSystem 11.0.28976.849 (28862)
    			Content-Length: 252
    			v=0
    			o=3cxPS 200974270464 403475267585 IN IP4 187.132.114.36
    			s=3cxPS Audio call
    			t=0 0
    			m=audio 9024 RTP/AVP 8 0 101
    			a=fmtp:101 0-15
    			a=sendrecv
    05-apr-2013 11:59:59.665	Connected(UAS) from <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5 to <sip:315230784044@89.146.10.230:5060>;tag=7613b128
    05-apr-2013 11:59:59.665	L:27.1[Line:10000<<0523610878] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=7e32.f7c19841.0 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			SIP/2.0 200 OK
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 252
    			v=0
    			s=3cxPS Audio call
    			t=0 0
    			a=fmtp:101 0-15
    			a=sendrecv
    05-apr-2013 11:59:59.665	SendMsg from <sip:315230784044@89.146.10.230:5060>;tag=7613b128 to <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5
    05-apr-2013 11:59:59.658	~Target=Ext:Ext.800
    05-apr-2013 11:59:59.658	L:27.1[Line:10000<<0523610878]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
    05-apr-2013 11:59:59.658	~Route=Dev:sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27
    05-apr-2013 11:59:59.658	L:27.2[Ivr] has joined to L:27.1[Line:10000<<0523610878]
    05-apr-2013 11:59:59.658	Session 43105 of leg L:27.2[Ivr] is connected
    05-apr-2013 11:59:59.658	L:27.2[Ivr] got Connected.UAC Recv 200/INVITE from 127.0.0.1:40600 tid=9a08090dac0a9b1e Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-d8754z-9a08090dac0a9b1e-1---d8754z-;rport=5060
    			To: <sip:800@127.0.0.1:5060>;tag=d227a531
    			From: <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a
    			CSeq: 1 INVITE
    			Supported: replaces
    			User-Agent: 3CX IVR
    			Content-Length: 336
    			v=0
    			o=3cxVCE 283021470 255282255 IN IP4 127.0.0.1
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    05-apr-2013 11:59:59.658	Connected(UAC) from <sip:800@127.0.0.1:5060>;tag=d227a531 to <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a
    05-apr-2013 11:59:59.658	Remote SDP is set for leg L:27.2[Ivr]
    05-apr-2013 11:59:59.658	Answer SDP arrived on Leg L:27.2[Ivr];
    OnAnswer Recv 200/INVITE from 127.0.0.1:40600 tid=9a08090dac0a9b1e Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			SIP/2.0 200 OK
    			CSeq: 1 INVITE
    			Supported: replaces
    			User-Agent: 3CX IVR
    			Content-Length: 336
    			v=0
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    05-apr-2013 11:59:59.658	L:27.2[Ivr] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=84133e0c5a0ef106 Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			ACK sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-84133e0c5a0ef106-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 ACK
    			Content-Length: 0
    05-apr-2013 11:59:59.658	SendMsg from <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a to <sip:800@127.0.0.1:5060>;tag=d227a531
    05-apr-2013 11:59:59.657	L:27.1[Line:10000<<0523610878] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=7e32.f7c19841.0 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			SIP/2.0 180 Ringing
    			Contact: <sip:sip3wvp00420@187.132.114.36:5060;rinstance=0e4b38e92874cb54>
    			CSeq: 1 INVITE
    			Content-Length: 0
    05-apr-2013 11:59:59.657	SendMsg from <sip:315230784044@89.146.10.230:5060>;tag=7613b128 to <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5
    05-apr-2013 11:59:59.657	Provisional response arrived for session 43105 of Leg L:27.2[Ivr]
    05-apr-2013 11:59:59.657	L:27.2[Ivr] got Provisional Recv 180/INVITE from 127.0.0.1:40600 tid=9a08090dac0a9b1e Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			SIP/2.0 180 Ringing
    			CSeq: 1 INVITE
    			User-Agent: 3CX IVR
    			Content-Length: 0
    05-apr-2013 11:59:59.657	Provisional(180) from <sip:800@127.0.0.1:5060>;tag=d227a531 to <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a
    05-apr-2013 11:59:59.657	[CM505001]: Endpoint Ivr:800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:800@127.0.0.1:5060]
    05-apr-2013 11:59:59.657	[CM503002]: Call(C:27): Alerting Ivr:800 by contact <sip:800@127.0.0.1:40600>
    05-apr-2013 11:59:59.650	UacSession 43105 has formed leg L:27.2[Ivr]
    05-apr-2013 11:59:59.650	Answer from <sip:800@127.0.0.1:5060>;tag=d227a531 to <sip:0523610878@127.0.0.1:5060;nf=e>;tag=5e5f273a
    05-apr-2013 11:59:59.504	[CM503025]: Call(C:27): Calling T:Ivr:800@[Dev:sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27] for L:27.1[Line:10000<<0523610878]
    05-apr-2013 11:59:59.504	Route to L:27.2[Ivr] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=895c3d121608ed2f Call-ID=YmY3MDVhOWMyMWYwNjBiMzNiOTE3M2VkOWM1NDkxZGE.:
    			INVITE sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-895c3d121608ed2f-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 351
    			v=0
    			o=3cxPS 203557961728 136650424321 IN IP4 127.0.0.1
    			s=3cxPS Audio call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=sendrecv
    05-apr-2013 11:59:59.495	Outbound URI is used: sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27
    05-apr-2013 11:59:59.495	Added leg L:27.2[Ivr]
    05-apr-2013 11:59:59.464	[Flow] Call(C:27): making call from L:27.1[Line:10000<<0523610878] to T:Ivr:800@[Dev:sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27]
    05-apr-2013 11:59:59.464	[CM503027]: Call(C:27): From: Line:10000<<0523610878 (<sip:0523610878@192.168.1.8:5060>)  to  T:Ivr:800@[Dev:sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27]
    05-apr-2013 11:59:59.464	[CM503004]: Call(C:27): Route 1: from L:27.1[Line:10000<<0523610878] to T:Ivr:800@[Dev:sip:800@127.0.0.1:40600;rinstance=3999fcfb77aacc27]
    05-apr-2013 11:59:59.464	[Flow] Endpoint Ivr:800 has no forwarding rule on reason 'All calls'
    05-apr-2013 11:59:59.464	[Flow] Call(C:27): has built target endpoint: Ivr:800 for call from L:27.1[Line:10000<<0523610878]
    05-apr-2013 11:59:59.464	[Flow] Target endpoint for 800 is Ivr:800
    05-apr-2013 11:59:59.464	[Flow] Building target endpoint to 800 from <sip:0523610878@192.168.1.8:5060>
    05-apr-2013 11:59:59.464	[CM503010]: Call(C:27): Making route(s) from Line:10000<<0523610878 to <sip:800@192.168.1.8:5060>
    05-apr-2013 11:59:59.463	Remote SDP is set for leg L:27.1[Line:10000<<0523610878]
    05-apr-2013 11:59:59.463	OnOffer from <sip:0523610878@192.168.1.8:5060;nf=e>
    05-apr-2013 11:59:59.463	[CM505003]: Provider:[nowhere.Comm] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:sip3wvp00420@187.132.114.36:5060]
    05-apr-2013 11:59:59.463	Inbound DID: ''; Phonebook Name: ''
    05-apr-2013 11:59:59.458	[CM500002]: Call(C:27): Info on incoming INVITE from Line:10000<<0523610878:
    			Invite-IN Recv Req INVITE from 89.146.10.230:5060 tid=7e32.f7c19841.0 Call-ID=5ddb-4f9-35201395947-HLF-IMG-02-1-31.276.32.22:
    			INVITE sip:sip3wvp00420@187.132.114.36:5060;rinstance=0e4b38e92874cb54 SIP/2.0
    			Max-Forwards: 69
    			Contact: <sip:31523610878@31.276.32.22:5060>
    			CSeq: 1 INVITE
    			Expires: 300
    			Allow: INVITE, BYE, REGISTER, ACK, OPTIONS, CANCEL, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE
    			Supported: path, replaces, tdialog
    			P-Asserted-Identity: <sip:0523610878@sip3.nowhere.nl>
    			Content-Length: 370
    			Remote-Party-ID: <sip:0523610878@31.276.32.22>;party=calling;screen=no;privacy=off
    			v=0
    			o=Dialogic_SDP 512222 0 IN IP4 31.276.32.22
    			s=Dialogic-SIP
    			c=IN IP4 31.276.32.42
    			t=0 0
    			m=audio 8996 RTP/AVP 8 0 18 98 3 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:18 G729/8000
    			a=fmtp:18 annexb=yes
    			a=rtpmap:98 G726-32/8000
    			a=fmtp:101 0-15
    			a=direction:passive
    05-apr-2013 11:59:59.458	[CM503001]: Call(C:27): Incoming call from Line:10000<<0523610878 to <sip:800@192.168.1.8:5060>
    05-apr-2013 11:59:59.456	Line limit check: Current # of calls for line Lc:10000(@nowhere.Comm[<sip:sip3wvp00420@sip3.nowhere.nl:5060>]) is 1; limit is 2
    05-apr-2013 11:59:59.456	Blacklist check: number '0523610878', list: ''; result = false
    05-apr-2013 11:59:59.456	Dev(1):[sip:sip3wvp00420@sip3.nowhere.nl:5060 / sip3wvp00420]: PBX contact is public IP: <sip:sip3wvp00420@187.132.114.36:5060>
    05-apr-2013 11:59:59.448	Outbound URI is used: sip:89.146.10.230;lr;ftag=95ffcd055e0f78f7d5d397020e89288dd6f599e5;did=0b3.bda59fd4
    05-apr-2013 11:59:59.448	Dev(1):[sip:sip3wvp00420@sip3.nowhere.nl:5060 / sip3wvp00420]: Outbound is overriden with topmost RR: <sip:@89.146.10.230:5060>
    05-apr-2013 11:59:59.448	Dev(1):[sip:sip3wvp00420@sip3.nowhere.nl:5060 / sip3wvp00420]: PBX contact is public IP: <sip:sip3wvp00420@187.132.114.36:5060>
    05-apr-2013 11:59:59.446	[CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:800
    05-apr-2013 11:59:59.446	[Flow] Looking for inbound target: called=315230784044; caller=<sip:0523610878@:5060>
    05-apr-2013 11:59:59.446	CallerNameAddr: <sip:0523610878;nf=e>
    05-apr-2013 11:59:59.446	Tenant's phonebook has failed to load!
    05-apr-2013 11:59:59.446	Looking for phone number 0523610878 in tenant's 'default' phonebook
    05-apr-2013 11:59:59.446	No inbound caller ID reformat rule is defined, or it is disabled (0,,,,,)
    05-apr-2013 11:59:59.446	Line 10000 has been updated from DB
    05-apr-2013 11:59:59.445	IncomingCall: C:27 from <sip:0523610878@sip3.nowhere.nl:5060> to <sip:sip3wvp00420@187.132.114.36:5060>
    05-apr-2013 11:59:59.445	Added leg L:C:27.1[No endpoint yet]
    05-apr-2013 11:59:59.445	UasSession 43102 started
    05-apr-2013 11:59:59.445	Call from <sip:0523610878@sip3.nowhere.nl>;tag=95ffcd055e0f78f7d5d397020e89288dd6f599e5 to <sip:315230784044@89.146.10.230:5060>;tag=7613b128
