Debian 9 Stretch installation broken after 15.5.8801.3 update
Discussion in '3CX Phone System - General' started by phil.wade, Feb 13, 2018.
  1. phil.wade
    Jul 13, 2015
    12
    Debian 9 Stretch installation hosted in Azure.
    I just ran the 15.5.6354.2 to 15.5.8801.3 update from the #/app/updates/all page of the 3cx web app. After that I could not login to the web app, stated a server error, and phones didn't work. A consultant tried the same thing after recovering the backup of the drives, and same response. 3cx was off line for half a business day, really bad for business.
    Anyone else getting this?
    #1 phil.wade, Feb 13, 2018
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    I'd do a full install with the Debian ISO restoring from backup during the install. Should take less than an hour at most. I have 2 Debians working fine with latest SP outside of the call log issues.
  3. levbe
    Apr 27, 2008
    33
    @phil.wade
    I've the same issue, i get a "server error" when i try to login to the web console.
    Did you solved the issue ?
  4. phil.wade
    Jul 13, 2015
    12
    I have not tried a full install or tried anything since my last post. I'm hesitant to do anything until I have a lot of time on my hands to recover from another disaster.
  5. gallo
    Feb 7, 2018
    8
    I have made the mistake to do a fresh install on OVH with Debian 9. It cant be completed, I tried all the ways with different debians (8 & 9) and all the instructions, It stopped in the same point
    ........The following packages have unmet dependencies:
    3cxpbx : Depends: libcurl3 (< 7.52.1) but 7.52.1-5+deb9u4 is to be installed
    E: Unable to correct problems, you have held broken packages................
    I believe something happens with the latest update, I have made more than 3 installations in OVH with Debian 8 & 9 a few months ago with no problem
  6. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    What if… you do a fresh install of e.g. v15.5 SP2 on OVH with Debian 9 and then do a upgrade to the latest version?
    Do that work for you?
    I have 4 Debian installs working fine on SP3 HotFix.
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    @gallo
    Please check the file sources.list.d and let us know what repository do you see there.
    Connect via ssh and type
    Code:
    nano /etc/apt/sources.list.d/3cxpbx.list
    Also let us know what debian version you are running.
  8. gallo
    Feb 7, 2018
    8
  9. gallo
    Feb 7, 2018
    8
  10. gallo
    Feb 7, 2018
    8
  11. gallo
    Feb 7, 2018
    8
    I don't know if something changed in file sources but now everything seems OK, I did the installation twice (8 & 9) and the pbx is back.
  12. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Glad to see the issue has been resolved but just as an FYI in Debian 8 the file should contain:
    Code:
    deb http://downloads.3cx.com/downloads/debian jessie main
    For Debian 9 the repository should be:
    Code:
    deb http://downloads-global.3cx.com/downloads/debian stretch main
  13. Said CHAKIR
    Dec 24, 2016
  14. YiannisH_3CX
    May 10, 2016
    4,349
    274
  15. Said CHAKIR
    Dec 24, 2016
    ok thank you very much.
