Debian Cloud V15 - calls "out" forbidden
Discussion in '3CX Phone System - General' started by jhoneck@honeckoil.com, Dec 6, 2016.
  1. jhoneck@honeckoil.com
    Feb 19, 2009
    I am running V15 in the cloud on OVH. Running SBC V15 locally. I can receive calls in. But, calls OUT or between extensions, I get a forbidden error. This happened last week and I ended up rebooting everything and was then able to call out. Now I'm having the same problem and have uninstalled and reinstalled the SBC. Moved the SBC and reset everything with no luck.
  2. George_3cx
    George_3cx Guest
