Debian configuration problem
Discussion in '3CX Phone System - General' started by jonnyy, Nov 6, 2017.
  1. jonnyy
    Nov 6, 2017
    After initial debian configuration, the link for initial figuring does not work. What are the possible causes? I'm talking about the free version.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @jonnyy,
    If you chose option 1(for web browser) then by going to http://<ip of machine>:5015 from within the same LAN should be ok.
    If however you want to run the Web-Based installer from an external source outside the LAN, then you will need to port forward port 5015 TCP from your gateway to the machine of the 3CX.
