Debian Install - Firewall issue
Discussion in '3CX Phone System - General' started by complex1, Mar 3, 2017.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    This is for me the first time I have install Debian with the ISO provided by 3CX.
    All went well but I want to use a other listen port, not 5060.
    But after change this port in 3CX, reboot the system the firewall checker failed.
    It expect that port 5060 is open, but this is a other port.
    I have read that something has to be changed in iptables(?), but I don’t know how or where I can find this table.
    All ports can be left as default, except port 5060.
    For me Windows is no problem, but Linux is a different story.
    Hope somebody can advise me how to do this.
    Thanks for the help.
  2. mainc
    Jul 27, 2011
    I've been having a firewall failing even when we turn off our UTM's firewall COMPLETELY! There has also been no help from 3CX whatsoever. Very disappointed over here and I welcome contact from 3CX. Very buggy Linux distro at this point in time. Thinking about going with a different platform at this point.
  3. Elvin Mammadov
    Feb 3, 2017
    42
    I am having the same issue, couldn't find any solution yet.
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  5. andreaschr
    Oct 26, 2015
    91
    6
    Hi there,
    complex1:
    just run the flowing command from the terminal:
    for UDP
    iptables -I INPUT 1 -i eth0 -p udp --dport [_PORT_] -j ACCEPT
    for TCP
    iptables -I INPUT 1 -i eth0 -p tcp --dport [_PORT_] -j ACCEPT
    example for port 6060:
    iptables -I INPUT 1 -i eth0 -p udp --dport 6060 -j ACCEPT
    iptables -I INPUT 1 -i eth0 -p tcp --dport 6060 -j ACCEPT
    that's all but if you need to update the previous Iptable and close port 5060 and open 6060 you need to do something that requires more steps.
    mainc: I don't understand your comment
    "Very buggy Linux distro at this point in time"
    If you have any issues please feel free to reach out to 3CX Support.
  6. complex1
    Jan 25, 2010
    815
    49
    Hi andreaschr,
    Thank you very much for your answer.
    These commands are exactly what I was looking for.
    Now I can use them with confidence, without the iptable becomes corrupted.
    Thank you.
  7. m_mellon
    Mar 13, 2017
    The 3CX provided Deb distro leaves out a few desired options. One of which is the ability to access the server as a user. While the OS setup allows you to create a root user, logins are not enabled for said root user. It always bounces back, both via SSH and by hooking a monitor and keyboard up to the physical box. Also it does not allow the option to choose a disk to install GRUB. In my experience, the OS installer automatically /dev/sda, which turns out to be the Deb Live disk. It errored out each time and I ended up having to go with LiLo.
    Among other differences, using a standard Debian ISO provides me the option to build the server as it should be, and THEN I install 3CX over top.
    And yes, it is a dedicated server. No other roles occupy this server.
  8. Elvin Mammadov
    Feb 3, 2017
    42
    I added this into iptables, but after restart, I see it has not been saved.
  9. complex1
    Jan 25, 2010
    815
    49
    @Elvin Mammadov
    After changing the iptable, try this command:
    iptables-save > /etc/iptables/rules.v4
  10. Elvin Mammadov
    Feb 3, 2017
    42
    Thank you very much. I could save iptables. I also tried this options to open tcp and udp port in iptables:
    1. iptables -I INPUT -p tcp --dport 5062 --syn -j ACCEPT
    2. iptables -I INPUT -p udp --dport 5062 -j ACCEPT
    Is this method same as you offered?
    iptables -I INPUT -p tcp --dport 5062 --syn -j ACCEPT = iptables -I INPUT 1 -i eth0 -p udp --dport 6060 -j ACCEPT ?
  11. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  12. Elvin Mammadov
    Feb 3, 2017
    42
    I mean, you offered following methods to open port in iptables;
    But I opened ports with this method:
    iptables -I INPUT -p tcp --dport 6060 --syn -j ACCEPT
    iptables -I INPUT -p udp --dport 6060 -j ACCEPT
    I wonder, are these methods the same thing, both you offered us and I did?
  13. andreaschr
    Oct 26, 2015
    91
    6
    Hi ,
    Elvin Mammadov:
    the difference in the commands is that it opens the port only for the interface eth0.
    you also have specified --syn that you accept only packets with flags:FIN,SYN,RST,ACK/SYN for TCP.
    m_mellon:
    We have made this ISO as simple as possible so even clients with no experience with Linux can install it.
    If we include everything from full ISO it will be the same with just 2 extra commands.
    Please feel free to reach out to 3CX Support and explain them the issues you have.
  14. Elvin Mammadov
    Feb 3, 2017
    42
    I have added this to iptables:
    3. iptables-save > /etc/iptables/rules.v4
    Everything is okay. I checked that this ports are open (http://www.yougetsignal.com/tools/open-ports/). We can call with our deskphones, and softphones on computers without any problem. But in our internal office WIFI, while calling somewhere, we can't hear each others voice. Is it because of added port styles above?
    1. How can I delete these added ports?
    2. How to turn off firewall in 3CX Linux Debian?
    #14 Elvin Mammadov, Mar 17, 2017
  15. andreaschr
    Oct 26, 2015
    91
    6
    Can you run the firewall checker of the PBX?
    Go to Management Console -> Dashboard -> Firewall Check
    Let me know what is the results
  16. Elvin Mammadov
    Feb 3, 2017
    42
    I run firewall checker, everything is green.
    Then, just in case I changed sip port from 5062 to 5065 in 3CX network settings, but didn't add this port to iptables in Linux. Then I tested calls to outside via WIFI, I began to hear voices.
    Could you please help me how to change current port to another port in iptables? I know how to do it in Windows Firewall, but Linux is different. If it is not possible, do I have to delete current port and add 5065 port?
    I also want to mention that, by default --syn has been written for 5060,5061,5090 ports that accepts packets with flags:FIN,SYN,RST,ACK/SYN for TCP.
    I copied this from iptables.
    -A INPUT -p udp -m udp --dport 5062 -j ACCEPT
    -A INPUT -p tcp -m tcp --dport 5062 --tcp-flags FIN,SYN,RST,ACK SYN -j ACCEPT
    -A INPUT -p tcp -m multiport --dports 80,443,5000,5001,5015,5060,5061,5090 -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m conntrack --ctstate NEW -j ACCEPT
    -A INPUT -p udp -m multiport --dports 69,5060,5090,7000:9500 -j ACCEPT
