Solved Debian install link not working
Discussion in '3CX Phone System - General' started by Justin Benoit, Aug 29, 2017.
  1. Justin Benoit
    Aug 29, 2017
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Benoit,
    Please try the following command as you need to add the repo first and let us know.
    Code:
    wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add - echo "deb http://downloads.3cx.com/downloads/3cxpbx/ /" | tee /etc/apt/sources.list.d/3cxpbx.list
  3. Justin Benoit
    Aug 29, 2017
    The link is working now. Thank you, Justin
