Debian Management Console Service Won't Start
Discussion in '3CX Phone System - General' started by tecnoinfo, Mar 22, 2018.
  1. tecnoinfo
    Feb 5, 2017
    7
    I no longer have access to the console, it gives me a server error
    [​IMG]
    I edited the file /lib/systemd/system/3CXPhoneSystemMC01.service
    setting the parameter TimeoutStartSec = 600
    as recommended in other posts, but nothing
    does anyone have any advice?
    3cx is debian 8 SO installed in VM Hyperv
    in the last 4 months it has always worked without problems
  2. StefanW
    Jun 2, 2009
    1,155
    70
    can you go onto the debian via ssh and type
    apt-get update
    apt-get install 3cxpbx
    plz snapshot hos before execution (just in case...)
  3. tecnoinfo
    Feb 5, 2017
    7
    already done, nothing has changed. :(
  4. StefanW
    Jun 2, 2009
    1,155
    70
    does it update any packages on your host while running the statement?
  5. tecnoinfo
    Feb 5, 2017
    7
    I can also reinstall everything but I have only an old backup.
    and when I try to backup the backup via SSH
    I get this error:
    root@aigespbx:~# sudo -u phonesystem /usr/sbin/3CXBackupCmd --file=backuptest.zip --options=ALL --log=/tmp/backuptest.log
    TCX.Configuration.Exceptions.PhoneSystemException: ConfigServer is not connected
    at TCX.Configuration.PhoneSystem.Connect()
    at TCX.Configuration.PhoneSystem.get_Root()
    at GenericUtilsNet.ApplicationConfiguration.get_PhoneSystemRoot()
    at BackupCmd.Program.Main(String[] args)
    root@aigespbx:~#
  6. tecnoinfo
    Feb 5, 2017
    7
    Code:
    root@aigespbx:~#  apt-get update
    Trovato http://downloads.3cx.com jessie-testing InRelease
    Scaricamento di:1 http://security.debian.org jessie/updates InRelease [63.1 kB]
    Trovato http://downloads.3cx.com  InRelease
    Trovato http://downloads.3cx.com jessie-testing/main amd64 Packages
    Scaricamento di:2 http://security.debian.org jessie/updates/main Sources [216 kB]
    Ign http://httpredir.debian.org jessie InRelease
    Trovato http://downloads.3cx.com  Packages
    Scaricamento di:3 http://httpredir.debian.org jessie-updates InRelease [145 kB]
    Scaricamento di:4 http://security.debian.org jessie/updates/main amd64 Packages [514 kB]
    Trovato http://security.debian.org jessie/updates/main Translation-en
    Trovato http://httpredir.debian.org jessie Release.gpg
    Ign http://downloads.3cx.com jessie-testing/main Translation-it_CH
    Ign http://downloads.3cx.com jessie-testing/main Translation-en
    Ign http://downloads.3cx.com  Translation-it_CH
    Ign http://downloads.3cx.com  Translation-en
    Trovato http://httpredir.debian.org jessie-updates/main Sources
    Scaricamento di:5 http://httpredir.debian.org jessie-updates/main amd64 Packages/DiffIndex [10.9 kB]
    Scaricamento di:6 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3'688 B]
    Trovato http://httpredir.debian.org jessie/main Sources
    Trovato http://httpredir.debian.org jessie/main amd64 Packages
    Trovato http://httpredir.debian.org jessie/main Translation-it
    Trovato http://httpredir.debian.org jessie/main Translation-en
    Recuperati 952 kB in 6s (140 kB/s)
    Lettura elenco dei pacchetti... Fatto
    root@aigespbx:~# apt-get upgrade 3cxpbx
    Generazione albero delle dipendenze
    Lettura informazioni sullo stato... Fatto
    Calcolo dell'aggiornamento... 3cxpbx è già alla versione più recente.
    Eseguito
    I seguenti pacchetti sono stati mantenuti alla versione attuale:
      linux-image-amd64
    0 aggiornati, 0 installati, 0 da rimuovere e 1 non aggiornati.
  7. StefanW
    Jun 2, 2009
    1,155
    70
    you seam to have a stopped service which is called config service it self
  8. tecnoinfo
    Feb 5, 2017
    7
    I discovered that postgresql starts and then goes off. Perhaps this is the problem.
    does anyone have any idea how to solve?
  9. Legop
    Feb 22, 2018
    15
    I've had this happen twice, both times when creating an extension (and probably some specific misc steps during that). first time was on debian 8, and I rebooted the appliance. Ended up having to reinstall 3cx. Luckily I did have a recent backup.
    Second time was on debian 9, did not restart the appliance, instead typed this
    systemctl start 3CXPhoneSystemMC01
    directly into the console. After that it worked again.
