Debian Sip Server Stop
Discussion in '3CX Phone System - General' started by tony28, Mar 21, 2017.
Tags:
  1. tony28
    Mar 17, 2017
    After installing SBC on free edition (wget http://downloads.3cx.com/downloads/sbc/3cxsbc.zip, sudo bash 3cxsbc.zip), SIP server will not start after reboot.
    It shows got signal to stop:15
    How can I remove SBC or start SIP server without SBC?
    Where is a more detailed log to see what is causing it to fail.
    All services started until SBC was installed.
    #1 tony28, Mar 21, 2017
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi tony28,
    Please clarify what you mean " SBC on free edition (wget http://downloads.3cx.com/downloads/sbc/3cxsbc.zip, sudo bash 3cxsbc.zip), SIP server will not start after reboot." Did you install the SBC on the machine that running the 3CX phone system free edition?
  3. tony28
    Mar 17, 2017
    I installed the SBC on the machine that is running the 3CX phone system free edition. After I rebooted, the sip server will not start.
    #3 tony28, Mar 21, 2017
  4. saqqara16
    Jan 13, 2016
    45
    7
    You do not install SBC on the machine running 3CX System
    It is installed on a remote machine, that has local phones that need to connect back to the 3CX System
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi tony28,
    You do not need the SBC on the same machine that the 3CX phone system is hosted.
    First, try to take a back up of your 3cx phone system and then save this backup file to different location (download the zip file on your PC) and then try to completely clear the config files, database and repositories of 3CX-SBC by this command "apt-get remove 3cxsbc". Also please try to remove from repositories file manual the 3cxsbc repositories, you can find that file on this location /etc/apt/sources.list.d/3cxpbx.list.
  6. GiannosC_3CX
    GiannosC_3CX Guest
