Diego Rise
- Joined
- Aug 13, 2018
- Messages
- 6
- Reaction score
- 0
the UI asked for an upgrade. and after I proceeded 3CX seems to have collapsed.
I did change the version from jesse to stretch, but i still get the following:
apt-get install 3cxpbx
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: unattended-upgrades but it is not going to be installed
Depends: postgresql (>= 9.6) but it is not going to be installed
Depends: libcurl3 (>= 7.52.1) but it is not going to be installed
Conflicts: libssl1.0.0 but 1.0.1t-1+deb8u9 is to be installed
E: Unable to correct problems, you have held broken packages.
Suggestions?
Suggestions?
