Debug vs Release variables
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Dec 9, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I would like to be able to specify different values for project level variables based upon the debug or release build. It doesn't have to be any other variables, just the ones at the project level would be great. Then I don't have to keep changing the global values every time I deploy debug vs. release.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Interesting feature. We'll think about it for the next release.
    Thanks,
