Debug window
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Feb 11, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    What would make the Debug window stop working? The VAD is unable to open the debug window using View->Debug Window.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Maybe you resized the window to make its size = 0.
    Try renaming the file "%AppData%\3CX Voice Application Designer\3CX Voice Application Designer.layout" to something else. Then, the default layout should be loaded.
    If you don't want to load the default layout, you may try changing it manually with a text editor. For example, this is the Debug window section in that file when you resize it to 0:
    <DockingControlData>
    <DockedDimension>0</DockedDimension>
    <Cancelled>false</Cancelled>
    <DockingType>Bottom</DockingType>
    <Title>Debug</Title>
    <FloatingBounds>
    <X>0</X>
    <Y>0</Y>
    <Width>0</Width>
    <Height>0</Height>
    </FloatingBounds>
    <AutoHide>true</AutoHide>
    <DockingIndex>2</DockingIndex>
    <PanelIndex>0</PanelIndex>
    </DockingControlData>
    You can change DockedDimension to 200 this way:
    <DockedDimension>200</DockedDimension>
    Let me know if this works for you.
