DECT Phone with BLF?
Discussion in '3CX Phone System - General' started by humansys, Dec 21, 2017.
  1. humansys
    Oct 28, 2015
    11
    Are there any 3CX-supported DECT phones with an option to see BLF (specifically Shared Parking), even if buried in a menu somewhere?
  2. StefanW
    Jun 2, 2009
    1,216
    88
    in this case DECT needs to have the ability to transmit such statuses, which std. DECT does not have...
  3. leejor
    10,779
    286
    DECT sets tend to have a limited size display available, along with a set of basic functions, unlike a desk set with multiple (configurable) buttons. On some multi-line handsets, it is difficult enough to fit (cram in) the status of the lines you have access to. DECT is generally the choice where mobility (within a set environment) is key, you forgo the more advanced options, that you'd expect on a desk set.
