Dect Phones
Discussion in '3CX Phone System - General' started by Cynthia Slade, Nov 6, 2012.
  1. Cynthia Slade
    Mar 22, 2012
    45
    Hi We have a client that wants a wireless (Dect) solution. Is anyone using the tgp500 and if so, are you satisfied with the quality of the calls? Any issues we should consider? How many phones are you using? Is there any issue transferring calls? Establishing ring groups? Thank you for your help/advise.
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    TGP500 works fine though its a pain to configure in addition you have to select enable browser everytime you want to access the web gui. Which can be extremely annoying if you are managing the machine remotely. I'd go with the new Grandstream Dect Phones or anything else other than the TGP500's.
  3. greatlakes
    Nov 12, 2012
    We have a single TGP500 installed, and it seems to do the job. There was some creative configuration to make it work with shared parking, but everything else seems fine. Ring groups and transfers "just work".
  4. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Also testing TGP 500, call transfer, call conference, call hold, provisioning, working well, nice design (for me)... doesn`t support phonebook via provisioning
  5. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    #5 eagle2, Nov 18, 2012
