Default Audio input not working on Mac
Discussion in '3CX Clients' started by Davit Mrelashvili, Mar 22, 2018.
  1. Davit Mrelashvili
    Mar 22, 2018
    Hey all,
    This is my first post so I apologize if I do something incorrectly. I noticed that if I pick default audio input and output on Mac, I don't hear anything (while on all other voice dialing software, e.g. skype, it works, and it is the default for mac). I had to indicate specific headset.
    Is this a normal behavior or is there something I'm missing?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    14
    Yes that a normal behavior. Headset should be indicated on Mac client.
    Thank you
