Default options for new extensions
MTB Freak
Could there be a new feature to set default options for new extensions.
For instance I would like to set "Record all calls" to on for every new extension I create.
Reactions: dsimond
Upvote 6
That would really help a bit, yeah :)
3CX are working on 'Copy Extension' feature, this way you could create dummy extensions with the required settings and copy this extension when required
(Did not make v15.5 SP1, being worked on now)
Yes this really would be great, any additional automation feature would be great, especially scripted creation of extensions!
Looking forward to news on this!
You can create extensions using the Call Control API if you want to "script" the creation of extensions. That would also allow you to define defaults for your extensions... but obviously that does require writing some code.
Get 3CX - Absolutely Free!
3CX
