Default "Parameter Settings"
Discussion in '3CX Phone System - General' started by herbst, Jun 19, 2017.
  1. herbst
    Nov 20, 2009
    7
    I change one Parameter for test. For restore to default, I delete this param from list. But this don't help.
    Where is default "Parameter Settings" description. How to restore missing entry?
    https://www.3cx.com/blog/docs/3cx-phone-system-parameters-table/ is old
    My entry was near CDR_LOGGING_PATH, can somebody give me nearest params from fresh 3cx installation?
  2. agp
    agp 3CX Team
    Aug 19, 2015
    135
    21
    Hi @herbst ,
    Is this what you are looking for?
    Code:
    Description: Location where CDR Logs will be saved
    Value:
    Windows: C:\ProgramData\3CX\Instance1\Data\Logs\CDRLogs
    Linux: /var/lib/3cxpbx/Instance1/Data/Logs/CDRLogs
    Code:
    Description: 1: 1 file for all calls, 2: 1 file per call
    Value:1
    Code:
    Description: Size of file in MB. When the size of the CDR file is reached, the next call is processed and the file is saved with the date stamp and a new file is written to ensure uniqueness leaving it in the same folder.
    Value: 250
    Or was the parameter irrelevant to the CDR?
  3. herbst
    Nov 20, 2009
    7
    Hi, thx
    No, Description like log level, 6 max / verbose 2 to default
    Maybe it was CMLOG_VERBOSITY
    Now i have this entry at the end, but with empty Description
