Default Time Zome Provisioning Linksys SPA962
Discussion in '3CX Phone System - General' started by Phthisicus, Feb 3, 2010.
  1. Phthisicus
    May 2, 2009
    6
    I have a Linksys SPA 962: That has the profile rule set to:
    http://SERVER:80/management/provisioning/$MA.xml
    The default time it will take when it gets his information from the provisioning server is GMT-5
    I want the default to be GMT+1
    I have configured the settings:
    TIME_TIMEZONE_AASTRA Timezone in Aastra-compatible format NL-Amsterdam
    TIME_TIMEZONE_GRANDSTREAM Timezone in Grandstream-compatible format 780
    TIME_TIMEZONE_LINKSYS Timezone in Linksys-compatible format GMT+01:00
    TIME_TIMEZONE_SNOM Timezone in Snom-compatible format NLD+1
    TIME_NTP_SERVER NTP server pool.ntp.org
    Under Settings\Advanced\Custom Parameters:
    Can anyone help me ??
    Greetings
