Default Time Zone Provisioning SNOM
Discussion in '3CX Phone System - General' started by TSDKen, Aug 25, 2011.
  1. TSDKen
    Sep 29, 2008
    33
    I am setting up a small 3CX system with 5 SNOM phones. So far everything seems to be working, but I cant seem to set the correct time zone. I am using the auto provisioning feature, but after doing this I can no longer access the advanced tab on the phone itself. I assume there must be a way to edit to SNOM template to push out the correct time zone, but it all looks a little foreign to me, any help would be appreciated.
    Thanks,
    Ken
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    have you checked to make sure all the settigns are correct within 3CX Console at
    >> Settings > Phone Provisioning ?
  3. TSDKen
    Sep 29, 2008
    33
    Wow, that was easy, thanks so much for the quick reply.
    Ken
  4. davidbenwell
    Apr 27, 2010
    704
    no problem.
