Default to be assisted transfer not blind or configurable
Discussion in 'Ideas' started by frog, May 8, 2017.
Default to be assisted transfer not blind or configurable 5 5 13votes
5/5, 13 votes
  1. frog
    Sep 22, 2015
    36
    5
    Could we have an option so that the default option for transfer is assisted.
    In our experience it would be better to be assisted as if you don't want to speak to the other party you could hang up and then it would become a blind transfer
    business54 and netcare like this.
  2. GCollis
    Dec 11, 2014
    39
    6
    Simplicity in iteslf! Attended should be set as standard.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    how about per extension setup. everyone has a different preference.
    #3 craigreilly, May 12, 2017
  4. Dave-TTG
    May 15, 2017
    26
    9
    Agree on this one - It used to be easy to change BLF transfer to Attended by using a custom template, but since v15 custom templates have become impossible to manage due to the UI changes
  5. netcare
    Nov 11, 2009
    Agreed. Using a BLF or Expansion module to transfer needs to be attended by default.
    This should be just a template change I imagine. Yealink please.
    EDIT: I have found it in the Yealink T4X xml template and simply changed a single number to change the default behavior.
    #5 netcare, May 20, 2017
  6. Dave-TTG
    May 15, 2017
    26
    9
    Yeah you need to change
    #Define the way of DSS key when configuring as a transfer key; 0-Display Number, 1-Attended Transfer, 2-Blind Transfer (default);
    transfer.dsskey_deal_type = 2
    It's still a problem though, more so on v15 than v14 as it's so hard to maintain custom templates now. Having to delete and re-add all your ip-phones to change to an updated template can take hours!
    I'd be able to stick to default supported templates if there was an option to change BLF transfer behaviour.
    It would also be nice to be able to change ringtones without resorting to custom templates. The default queue tone (6) on the Yealink handsets is a weird classical music piece and customers hate it
  7. craigreilly
    Feb 1, 2012
    3,551
    298
    But now you've put yourself in an unsupported situation which is why it would be nice for template overrides or more options within the extensions.
  8. Dave-TTG
    May 15, 2017
    26
    9
    Yeah totally. Having to delete and re-add all your phones just to log a ticket with 3CX is another reason why we're now avoiding custom templates where possible. Like i said it wasn't so bad on v14 as you'd just change the phone type drop down and reboot the phones.
    Now you have to copy the MAC address, note down the STUN ports/SBC IP, delete the phone, add a new phone and paste in the MAC, then add the STUN/SBC detailts. For every single phone...ouch
  9. dsm
    dsm
    Aug 2, 2010
    Having a field in the extension/phone setup that would change the transfer mode from attended/unattended would get my vote!
  10. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,564
    237
    @nickybrg I believe this can be marked as completed with v15.5 SP1
  11. decalabs
    Sep 21, 2016
    16
    5
    No. In v15.5 SP1 this is configurable only on Yealink phones. On other phones linke Snom you still have this problem. It should be possible to disable blind transfer systemwide.
  12. cobaltit
    Mar 22, 2012
    1,564
    237
    @decalabs
    It's on Fanvil and Htek phones as well so it looks like only the Snom is missing for the supported phones. Can be listed as in-progress then.
