Define different opening hours
Discussion in '3CX Phone System - General' started by jesperkjeldsen, Jun 23, 2008.
  1. jesperkjeldsen
    Apr 22, 2008
    9
    Is it possible to define opening hours different for some lines?
    It's in use in a company with several groups who dosn't share the same working hours.
    Reagards
    Jesper
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It is in the features list for next versions.
