Delay at Answering of Calls
Discussion in '3CX Phone System - General' started by Mullenlaw, Jan 27, 2012.
  1. Mullenlaw
    Apr 13, 2011
    53
    What would cause a delay when a call is initally answered?
    When we call someone via intercom (and other calls) there is delay in intial communication when they answer the call.
    "Hello, Hello..." and then the call happens...
    Any ideas? Is that a codec thing? Are the phones changing codec to try and find a common best codec?
    :idea:
    10,732
    277
    You haven't specified what type of sets are involved. Are they all of the same type?
  3. Mullenlaw
    Apr 13, 2011
    53
    Internally Yealink T38G's
    Receptionist is using VoiceOperatorPanel (soft phone)
    Externally? ?????
  4. leejor
    10,732
    277
    It sounds similar to this issue...
    http://www.3cx.com/forums/queue-answer-delay-9040-15.html
    Same make of set, suspicious...
    Are you running the latest firmware?
  5. Mullenlaw
    Apr 13, 2011
    53
    Not the latest firmware yet.
    Thanks for the link - will check it out...
