Delay before getting dial tone/dialing
Discussion in '3CX Phone System - General' started by exmoskl, Nov 15, 2013.
  1. exmoskl
    Oct 26, 2010
    7
    Evening all
    I have an issue that appeared after working ok for a number of months. V11 installation, all updates applied, with Grandstream GXP2124 handsets for clients. When lifting the handset, there is a delay of a couple of seconds before getting a dial-tone, or dialling numbers.
    Any ideas on what could be causing this? There have been no changes to 3CX or the server OS/LAN infrastructure that we suspect could be impacting/be responsible.
    Thanks in advance for any guidance/assistance.
    10,375
    231
    Dialtone is generated internally, on VoIP sets, so should not be affected by the network, unless the set were not currently registered. I've never heard of an option, nor would understand the point of an option delaying dialtone, when the handset is lifted.
    Have you tried doing a full reset on the phone(s) and reloading the configuration?
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Take a look an uptime for that phone. I also had issues like you. After restarting the phone it become normal again (uptime was more than 200 days :))
