Delay connecting remote audio on Skype calls
Discussion in '3CX Phone System - General' started by plewis, Feb 2, 2012.
  1. plewis
    Mar 25, 2011
    We are using skype as a sip trunk (VOIP provider), and we are experiencing a long delay before hearing the far end, so we miss the greeting, "hello," etc. Is there a way to adjust "answer supervision," or is there another answer to this?
    11,071
    323
    Do you have any other VoIP trunks that this does or doesn't happen on? Any sort of "answer supervision" SIP message should be instant. What type of sets are you using? Some users have had delayed audio issues with some Yealink sets.
    Does the 3CX log (verbose) show any signs of a problem?
