Delay in answering Queue calls
Discussion in '3CX Phone System - General' started by IT-AKM, Jan 26, 2017.
  1. IT-AKM
    Jan 26, 2017
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi IT_AKM,
    Can you confirm PBX version & patch, also exactly how you are setup?
    Regards
  3. IT-AKM
    Jan 26, 2017
    Hello. I installed ALL Patches and Updates. We use V15
    Setup: we use public IP and SSL from 3cx.com
  4. MRM
    MRM
    Dec 21, 2016
    53
    You never mentioned the hardware concerned, please confirm.
  5. IT-AKM
    Jan 26, 2017
    the 3CX Systems run on a virtual machine with Windows Server 2012R2. It has 8GB RAM and 4 CPU.
    the SIP trunk we make with BeroNet and a E1 (30 Lines) connection to Colt Provider.
  6. MRM
    MRM
    Dec 21, 2016
    53
  7. IT-AKM
    Jan 26, 2017
    yes I installed the Beronet exaclty like this. As I mentionded: Direct Calls are all okay without delay. Only Calls in the Queue are delayed.
