. and here is a call answered ont eh same extn via 3CX Phone on my PC.
16:20:00.677 [CM503008]: Call(12): Call is terminated
16:19:50.722 [CM102001]: Authentication failed for SipReq: REGISTER 89.0.3.1 tid=1964081352 cseq=REGISTER
[email protected]:5060 / 51361 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
16:19:43.297 [MS105000] C:16.3: No RTP packets were received:remoteAddr=89.0.9.8:40022,extAddr=0.0.0.0:0,localAddr=89.0.3.1:7068
16:19:42.322 [CM503008]: Call(16): Call is terminated
16:19:39.688 Currently active calls - 2: [12,16]
16:19:37.998 [MS105000] C:17.2: No RTP packets were received:remoteAddr=89.0.9.8:40022,extAddr=0.0.0.0:0,localAddr=89.0.3.1:7064
16:19:36.709 [CM503007]: Call(16): Device joined: sip:
[email protected]:64245;rinstance=a0d2de78622aa7b0
16:19:36.702 [MS210003] C:16.3:Answer provided. Connection(transcoding mode[unsecure]):89.0.3.1:7068(7069)
16:19:36.701 [MS210002] C:16.1:Offer provided. Connection(transcoding mode): 86.188.246.34:9018(9019)
16:19:36.700 [MS210000] C:16.3:Offer received. RTP connection: 89.0.9.8:40022(40023)
16:19:36.699 Remote SDP is set for legC:16.3
16:19:36.699 [CM505001]: Ext.103: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:
[email protected]:5060]
16:19:36.699 [CM503002]: Call(16): Alerting sip:
16:19:36.695 [CM503008]: Call(17): Call is terminated
16:19:36.480 [CM503025]: Call(16): Calling @[Dev:sip:
[email protected]:64245;rinstance=a0d2de78622aa7b0]
16:19:36.441 [CM505003]: Provider:[NODE4] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
16:19:36.440 Replaces: C:17.2
16:19:36.440 Refer: from=<sip:
[email protected]>;tag=e72fd766; to="BM TEST:+447980586770"<sip:
[email protected]:5060;nf=e>;tag=141bb30d; RefTo=<sip:
[email protected]:5060;nofwd=1;tag3cx=13-TDTOSJSXSJ?Replaces=YTQ2YjhiNDc3ZTk4NGUzMDE1YWMwM2RhY2RmYzMyZTg.%3Bto-tag%3D4d6fa71a%3Bfrom-tag%3D5d036919>;tag=4d6fa71a
16:19:36.434 Session 10231 of leg C:17.1 is confirmed
16:19:36.398 [CM503003]: Call(17): Call to sip:
[email protected] has failed; Cause: 487 Request Terminated; from IP:89.0.5.0:5060
16:19:36.214 [CM503007]: Call(17): Device joined: sip:
16:19:36.212 [CM503007]: Call(17): Device joined: sip:
[email protected]:5488
16:19:36.208 [MS210005] C:17.1:Answer provided. Connection(proxy mode):127.0.0.1:7062(7063)
16:19:36.206 [MS210001] C:17.2:Answer received. RTP connection[unsecure]: 89.0.9.8:40022(40023)
16:19:36.205 Remote SDP is set for legC:17.2
16:19:32.726 [CM505001]: Ext.103: Device info: Device Identified: [Man: GrandStream;Mod: GXP series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2100 1.0.1.110] PBX contact: [sip:
16:19:32.726 [CM503002]: Call(17): Alerting sip:
[email protected]:5060;user=phone
16:19:32.704 [CM505001]: Ext.103: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:
16:19:32.704 [CM503002]: Call(17): Alerting sip:
16:19:32.557 [CM503025]: Call(17): Calling Ext:Ext.103@[Dev:sip:
[email protected]:5060;user=phone]
16:19:32.555 [MS210004] C:17.3:Offer provided. Connection(proxy mode): 89.0.3.1:7066(7067)
16:19:32.549 [CM503025]: Call(17): Calling Ext:Ext.103@[Dev:sip:
16:19:32.547 [MS210004] C:17.2:Offer provided. Connection(proxy mode): 89.0.3.1:7064(7065)
16:19:32.501 [CM503004]: Call(17): Route 1: Ext:Ext.103@[Dev:sip:
[email protected]:64245;rinstance=a0d2de78622aa7b0,Dev:sip:
16:19:32.500 [CM503010]: Making route(s) to <sip:
[email protected]:5060;nofwd=1;tag3cx=13-TDTOSJSXSJ>
16:19:32.500 [MS210000] C:17.1:Offer received. RTP connection: 127.0.0.1:32024(32025)
16:19:32.499 Remote SDP is set for legC:17.1
16:19:32.499 [CM505001]: Ext.820: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX Queue;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue Manager (q=820)] PBX contact: [sip:
16:19:32.496 [CM503001]: Call(17): Incoming call from Ext.820 to <sip:
16:19:32.489 [CM500002]: Info on incoming INVITE:
INVITE sip:
[email protected]:5060;nofwd=1;tag3cx=13-TDTOSJSXSJ SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-d8754z-d664d97ada17e477-1---d8754z-;rport=5488
Max-Forwards: 70
Contact: <sip:
[email protected]:5488>
To: <sip:
[email protected]:5060>;tag=5d036919
Call-ID: YTQ2YjhiNDc3ZTk4NGUzMDE1YWMwM2RhY2RmYzMyZTg.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="820",realm="3CXPhoneSystem",nonce="414d535c055aec9457:c5d83e3560e5ed4871244d783a18adb0",uri="sip:
[email protected]:5060;nofwd=1;tag3cx=13-TDTOSJSXSJ",response="dd6845e0bdad23b6eca67cbe645c2dc0",algorithm=MD5
Supported: replaces
User-Agent: 3CX Queue Manager (q=820)
Content-Length: 0
Because there was no RTP audio (different problem) I was not able to confirm if the delay qwas there but is seems there is some difference to teh call setup.
