Delay in audio
Discussion in '3CX Phone System - General' started by Arunesh Dutta, Sep 11, 2017.
  1. Arunesh Dutta
    Sep 9, 2017
    36
    Hello all
    Have made a new setup.PBX running in google cloud.Extensions get connected and dialing works fine.My softphone is connected to 10Mbps and other location 8Mbps line with only other single user with plently bandwidth available.Observed there is delay in conversation how this can be rectified.
  2. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    @Arunesh Dutta kindly try to reorder codecs priority in the extension provisioning settings. If you use G711u/a it should solve your issue.
    Good luck!
  3. Arunesh Dutta
    Sep 9, 2017
    36
    Thanks a lot delay has been reduced
