Delay When Dialing 3CX Version 10
Discussion in '3CX Phone System - General' started by RogerPiggott, Aug 27, 2015.
  1. RogerPiggott
    Aug 27, 2015
    Good afternoon,
    I am currently using 3cx version 10. And when making any call (internal/outbound) there is a delay for about 4 to 5 seconds. This even occurs when using the # button. However, when making a sip call directly to each phone (via url), it rings instantly.
    Any suggestions would be greatly appreciated.
    Thanks in advance.
    Roger
  2. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    Version 14 is being released on Tuesday 9/1.
    You are so far behind (v 10 came out Mar 2011) as to be shocking.
    How about getting to a current or 1 prior version in return for some support?
    Regards,
    Allen
  3. leejor
    11,291
    361
    What type of sets are you using? Is there more than one type, if so does the delay occur on all of them. The # may not be the end of dialling signal on your sets.
    Did you look in the 3CX Server log to see how long it took to set up a connection once 3CX began processing the call? Is there a delay? If not, then the set is waiting (for more digits) before sending to the PBX despite the #.
  4. RogerPiggott
    Aug 27, 2015
    Good morning,
    Thanks for the update. We are currently using various Polycom models; ranged from IP 450- IP 670.
    Please see below for a call log taken from the 3CX server
    11:46:03.186 [CM505001]: Ext.2118: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [PolycomVVX-VVX_1500-UA/3.3.3.0072] PBX contact: [sip:2118@10.11.40.200:5060]
    11:46:03.186 [CM503002]: Call(6351): Alerting sip:2118@10.11.11.31:5060
    11:46:02.021 [CM503025]: Call(6351): Calling Ext:Ext.2118@[Dev:sip:2118@10.11.11.31:5060]
    11:46:01.892 [CM503004]: Call(6351): Route 1: Ext:Ext.2118@[Dev:sip:2118@10.11.11.31:5060]
    11:46:01.891 [CM503010]: Making route(s) to <sip:2118@10.1.40.200;user=phone>
    11:46:01.769 [CM505001]: Ext.2119: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_550-UA/3.3.3.0069] PBX contact: [sip:2119@10.1.40.200:5060]
    Kind regards
    Roger
  5. leejor
    11,291
    361
    It would appear that the delay is happening in the set itself. Looking over the documentation for the Polycom (and perhaps another forum member with Polycom experience can add some comments here), the phones appear to have an internal Digit Map, that if configured correctly, would automatically send the digits immediately, upon a match.
    http://support.polycom.com/global/documents/support/technical/products/voice/Digit_Map_Changes_TB11572.pdf
    It also appears that there is a "send" button to use after dialling...
    http://supportdocs.polycom.com/PolycomService/support/global/documents/support/user/products/voice/SoundPoint_IP450_Quick_User_%20Guide_UCS_3_3_0.pdf
    You may also try pre-dialling (handset on-hook), then after all digits are entered, pick up the handset. I don't know if this will work or not, but it does on some makes of sets.
  6. RogerPiggott
    Aug 27, 2015
    I don't think it can be the handsets we are using because we also use GrandStream gateways to accommodate for analog phones and they too have the same issue. This is really mind boggling. We ever restarted our server multiple times but the issue still stands.
    Any other suggestions would be greatly appreciated.
    Regards
    Roger
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    I have seen the Grand-stream delay on ATA's when the correct dial string is not provisioned.
  8. RogerPiggott
    Aug 27, 2015
    It's not only on the gateways. It is on the VOIP Polycom phones as well. Is there a setting on 3CX ver. 10 that could affect this?
    Regards
    Roger
  9. leejor
    11,291
    361
    The log you posted shows about 3 seconds to complete a call, so I don't suspect that it is 3CX. I think that it is the set waiting for additional digits before sending. Four to five seconds is the "normal" wait timeout. Have you tried pressing the Send button, that shows in the user documents that I attached the link for? Have you looked into creating a digit map in the set?
