Delay when doing call pickup *20*
Discussion in '3CX Phone System - General' started by Gav, Feb 22, 2018.
  1. Gav
    Gav
    Oct 3, 2017
    44
    Using Fanvil x4
    Programmed Custom Speed Dial on BLF to dial *20*
    but when people use the speed dial, there is a 4 second delay. This is normal because the phone has a pause in it during dialling phase.
    Pressing # gets rid of the delay, but when I program the custom speed dial button as *20*#, it doesnt work.
    What can I do to remove the 4 second delay?
    10,752
    285
  3. Gav
    Gav
    Oct 3, 2017
    44
    I looked at dial plan but couldn't fathom anything out.
    The peculiar thing is we also have a custom speed dial for a page group that works perfectly.
    The number being *805804 - whenever this is used it dials instantly, so no 4 second delay.
    I cannot see what difference that has to the *20* , other than length?
  4. leejor
    10,752
    285
    If it is the set that is causing the delay, then there must be something in the options that allows one number to be sent intermediately, and one only after that time-out period. Not having used Fanvil sets before, I can only go by what the dialplan options seen to show in the manual. There may be options elsewhere that another forum member is aware of.
  5. leejor
    10,752
    285
    Check section 8.13 Dial Peer, they call it
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Gav
    Can you please let us know of the PBX version you are running as well as the firmware version of the phone and the provisioning type (local, STUN, SBC). Also are you using the default 3CX templates?
    I have tried to replicate your scenario but i was not able as the call is picked up as soon as the DSS key is pressed. My phone is local to the PBX with the latest supported firmware and the default template
