Delay when using Jabra PRO 930 on a Mac
Discussion in '3CX Clients' started by Thomas Liesner, Dec 11, 2017.
  1. Thomas Liesner
    Oct 23, 2017
    23
    when using a device like a Jabra PRO 930 together with the Mac softphone we encounter a long delay after beginning the call before i actually get heard or hear anything. There seems to be something like a "now audio is enabled" event and then it works, but it takes 2 or 3 seconds. This is very irritating for the callers. The same headset connected to a Windows softphone works without issues? Any hints?
    TIA,
    Thomas
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    Hi Thomas
    On Apple (both MAC and iOS) opening the soundcard is much slower than in Windows, especially for bluetooth and, unfortunately, we don't have control over it. As former Windows developer, I've been and I am very frustrated too by this annoying issue but, as I said, we weren't able to solve it so far.
    Sorry for inconvenience
    vali
  3. Thomas Liesner
    Oct 23, 2017
    23
    Hi Vali,
    thanks for the quick response! The Jabra PRO 930 communicates via DECT with a dockingstatiuon which is connected to the Mac via USB. So no bluetooth involved. I will recheck with other softphones (Bria, Starface). Could this also be a headset issue?
    TIA,
    Thomas
  4. Vali_3CX
    Dec 12, 2008
    1,531
    69
    No, I don't think it's a headset issue. We started developing our client since Snow Leopard, and this issue, this delay, was consistent until latest OS, and a huge difference compared to Windows.
