Delayed dissconnect
Discussion in '3CX Phone System - General' started by dave151, Jun 13, 2007.
  1. dave151
    Jun 13, 2007
    6
    HI all, I've just switched from asterisk to 3cx which I find is alot more user friendly when making changes although I have a few issues which I havent' found the answer to by searching. When I receive and incoming call from my pstn line to any ip phone( hard or soft ) The line will stay connected even after the caller has hung up. It ranges from 2 to 3 minutes after the person has hung up. My SPA3102 still says the line is connected as does 3cx. On hook voltage is -45 and off is -6V.
    here's my log:
    08:17:31.718 StratInOut::eek:nCancel Call(C:8): Call from Ln:10000@Spa3102 to 999 has been terminated
    08:15:06.687 CallLegImpl::eek:nConnected Call(C:8): Created audio channel for Ln:10000@Spa3102 (192.168.2.11:16470) with Media Server (192.168.2.10:7020)
    08:14:51.578 CallConf::eek:nProvisional Call(C:8): got response from 100
    08:14:51.546 CallConf::eek:nIncoming Call(C:8): Incoming call from Ln:10000@Spa3102 to sip:10000@192.168.2.10
    You will also notice it doesn't forward callerid info but i'm still learning.
    Keep up the good work 3cx.
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hey Dave
    welcome to the forum. Have a look at your Voice/PSTN line/
    tab and scroll down to the PSTN Disconnect Detection subsection of the page. I don't know exactly what to suggest . But have a look at
    Detect Polarity Reversal
    Detect PSTN Long Silence
    PSTN Long Silence Duration
    fields as well as the rest of the fields in that subsection. I am still trying to figure out how to eliminate this problem, but I am positive the answer must be hidden somewhere there.
    I know this is not an answer but it could be push in the right direction.
  3. Anonymous
    Anonymous Guest
    Dave,
    http://www.dayboro.biz/Downloads/manuals/
    Is the latest manual for the combination of the spa3102 with 3CX. Not a complete product yet.
    It can be a range of things, but start with the obvious ones like the call progress tones work your way from there, it is most likely in your regional settings, or in the PSTN Disconnect Detection section like suggested by support.
    Comming from an astrix world, you know howto fiddle :).
    Let me know if you have any further troubles.
