Delayed outbound calling from 3CX Client (Mac OS X)
Discussion in '3CX Phone System - General' started by jacobtalbot, Dec 29, 2016.
  1. jacobtalbot
    Dec 13, 2016
    17
    Hello
    We are trailing the 3CX Client and for some reason there is a large delay when making the outbound call, up to 10 - 15 seconds. I have tried the same number on a desk phone and it's delay is only a few seconds - connected to the same extension.
    Can someone please provide some insight?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    hello there,
    Could you please provide some more info regarding what Mac OS are you running and what version client are you running?
    Also are you on the latest service pack of V15 and have you downloaded the latest client from the updates section of the management console?
    How about extension to extension? is there any delay there?
  3. jacobtalbot
    Dec 13, 2016
    17
    Hello
    I am running macOS Sierra. Client version is 15.1.0.66. As far as I am aware we are running the latest PBX software. I am unsure as to where to find the latest service pack of V15.
    Extension to extension calls are also delayed. I have also done the latest updates in the PBX also.
  4. YiannisH_3CX
    May 10, 2016
    5,486
    357
    You can find your build number on the Dashboard of the management console under the information column next to the license. 2016-12-30_15h05_48.png
    you are running the latest client though. Have you tried a windows client? Does that have the same delay as well?
  5. jacobtalbot
    Dec 13, 2016
    17
    Hello
    We are on the latest build for 3CX. Version 15.0.60903.0
  6. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    Hi Jacob
    When you say delay, it means
    1 - the call is established imediately but it has audio delay; or
    2 - the call starts dialing but it establishes after that delay?
  7. jacobtalbot
    Dec 13, 2016
    17
    The day is, the number will be inputted, but there will be a delay before the call will dial and start ringing.
  8. Sergej Nachtigal
    Jan 3, 2017
    We have the same issue with our Mac clients. It's a delay of ~16 seconds until the call is established. Same behavior for inbound and outbound calls.
    We use the Linux PBX, version 15.0.60903.0.
    The Windows client is working fine. Except calling a Mac client using the Windows client.
    Any news on this issue?
  9. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Hi Jacob, Sergej
    Please you try open the 3CX client/Settings/Audio menu and there, instead of "default" devices, select the exact ones you want to use, then try to make a call to see if there's a change in that delay and tell me the result.
    vali
  10. jacobtalbot
    Dec 13, 2016
    17
    I have done all of the audio settings and the results are the same.
  11. Vali_3CX
    Dec 12, 2008
    1,476
    67
    If you have a ticket open to our tech support, can you please send us the logs? I'm still assuming is something related with the sound devices (a bluetooth or USB) but only the logs might reveal.
  12. Sergej Nachtigal
    Jan 3, 2017
    Changing the audio device makes no difference.
    I run some tests and recorded the network traffic on the device. On macOS it takes 5 seconds until the 3CX client contacts the 3CX server the first time after starting the call. On Windows it's less than one second until the 3CX client contacts the server.
    Internal calls:
    - macOS <-> macOS: It takes about 5-7 seconds until the call is established
    - macOS <-> Windows: It takes about 5-7 seconds until the call is established
    - Windows <-> Windows: It takes about 1-2 seconds until the call is established
    External calls:
    - Windows <-> external: It takes about 5-7 seconds until the call is established
    - macOS <-> external: It takes about 12-15 seconds until the call is established
    We use macOS Sierra on our computers.
    Any further ideas? :).
    Thanks.
  13. Simon Hoy
    Jan 30, 2017
    I have this problem too! I am running Sierra and have the 3CX Client v15.1.0.66. I have only just installed 3CX today although I have used previous versions. I thought I was doing something wrong, until I tested the system using the 3cx iPhone app instead of the Mac and it worked instantly.
    I am using the built in Mic and Speakers which are set as the devices in settings. I don't have any bluetooth or USB audio devices at the moment.
  14. Vali_3CX
    Dec 12, 2008
    1,476
    67
    OK, we found the problem - the fix will be available starting with ver 15.1.0.68
  15. ang3l12
    Feb 9, 2017
    Any update on when this new version will be available?
  16. ang3l12
    Feb 9, 2017
    Asking again for when this new version will be available? The soft phone is almost unusable at this moment with this issue going on, as most people will hang up after 15 seconds of ringing. Thanks!
