delete and re-create extension
Discussion in '3CX Phone System - General' started by cfive, Dec 16, 2010.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    5
    Are there any know issues if you delete an extension, and then re-create it with the same configuration exactly (user, extension #, pin #, password, etc.)?
    I did just that - the extension previously belonged to a queue, and is now back in the queue. However, it will not be notified of calls to that queue. There are 4 other extensions in the queue that work fine.
    You can call this problem extension directly, forward call to it, make calls from it, change the status with the Assistant, etc. All is fine, other than it does not get notified of calls to the queue it belongs to.
    I can't seem to find the reason - any pointers would be appreciated!.
    Thanks, Les.
    10,582
    249
    The 3CX log showing a call being presented to the extension might be a way to start troubleshooting. Did you delete every instance of the extension (take it out of queues/ring groups) before actually deleting the extension itself?
  3. cfive
    cfive Member
    Aug 20, 2009
    284
    5
    Hi leejor,
    No, I never removed it from the groups and queues before deleting - but in my experience deleting the object itself has typically removed it completely, in the past at least.
    The log clearly shows the other queue extensions being notified (it's a ring all queue), with the exception of this one. Also on the assistant, you can see the other extensions ringing, but not this one.
    I deleted the queue, and re-created it. We'll see if that brings any joy when they get to work tomorrow.
    Thanks for the reply - Les.
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    5
    Rebuilding the Queue seems to have fixed it. I deleted the Queue, and then added a new Queue with the same settings and the extension is now being notified as expected.
    I'm not actually sure if the issue was created by removing and re-creating the extension - it may have been a hangover from the upgrade from v8 to v9 - when doing version upgrades it seem that one often has to go through most, if not all, of the configuraiton and click "apply" to get things set again.
    Anyhow, the system is functioning as intended now :p
    Thanks - Les.
