Delete button option on Phone Extension screen
Discussion in 'Ideas' started by monarch1, Apr 7, 2016.
  1. monarch1
    Jan 6, 2010
    5
    Removing a phone device from the phone provisioning tab of the extensions screen is not very intuitive. You need to blank out the MAC and choose "Select Phone Model" for the Model field. Could a delete button option be created for this purpose on that screen?
