Delete call logs
Discussion in '3CX Phone System - General' started by gbarnes, Aug 11, 2007.
  1. gbarnes
    Aug 3, 2007
    83
    Just wondering if there is an option I missed to delete my call logs.
    Graeme.
  2. Anonymous
    Anonymous Guest
    Nope, you did not. There is none.
    Perhaps something to add to the feature list, that we can purge records based upon date and time stamp? Same as report generation, once the report is generated be able to purge. Or even better Archive so instead of creating a CSV file, have those records ported to a ZIP file and purged from the DB. So you still have them for what ever purpose (law enforcement agencies can ask for records dating back 5 yrs or so so if you use this app in production please do not delete :) but check with your local agencies).
    Just a thought.
  3. gbarnes
    Aug 3, 2007
    83
    Archive, thanks
    Thanks Itfarmer!!
    Yes that would be nice. Archive first, then on deletion a popup disclaimer or something.
    So you have to do an archive first, then after that its up to you!
    Our call recordings transfer to DVD are done monthly, so it would be nice to put the logs onto the same DVD sets.
    Graeme.
  4. Anonymous
    Anonymous Guest
    I am playing with some PHP code that allows you to view the call logs (outside 3CX) I might add a delete function to it.
    Nothing special just something I am playing with.
