Delete Digital Receptionist WAV Files
Discussion in '3CX Phone System - General' started by danielt, Dec 14, 2017.
  1. danielt
    Mar 2, 2017
    Simple Question:
    How can I delete old WAV Files that are not used anymore in a Digital Receptionist? At a normal mailbox I can Manage the files, but this button isn't available at Digital Receptionist.
    Greets
    Daniel
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @danielt
    IVR Prompts, including those that you have recorded are stored in the following folders depending on your OS:
    Windows: C:\ProgramData\3CX\Instance1\Data\Ivr\Prompts
    Linux: /var/lib/3cxpbx/Instance1/Data/Ivr/Prompts
    You can manually delete them from the above folders.
