Delete Extension
Discussion in '3CX Phone System - General' started by sabrehagen, Apr 20, 2013.
  1. sabrehagen
    Apr 20, 2013
    6
    I tried following the guide on the forum do delete an extension (seen here: http://www.3cx.com/forums/delete-extension-17900.html) but I think it may be for an older version as I cannot find the "delete extension" button mentioned in the post.
    This is a screenshot of my screen that the guide above mentions: http://oi36.tinypic.com/351s3tf.jpg
    Can you please tell me how to delete an extension in 3CX 11?
    Thanks,
    sabrehagen
  2. Stef - Venema Advies
    Apr 10, 2012
    26
    Read what he says.
    Select Extensions from the menu on the left, when the list of extensions appear on the right, highlight the one you want to delete then select Delete Extension from the menu just above the window.
    Just click 1 time on Extensions.
    The Extensions will appear in the right of it.
    Click on the Extension in the right screen.
    Than the delete button will appear above the window.
  3. sabrehagen
    Apr 20, 2013
    6
    Wow, I completely read that a different way the second time. The ambiguity led me to think he meant click the number in the left hand column after the ones on the right appear. English is a funny thing! Thank you.
  4. Stef - Venema Advies
    Apr 10, 2012
    26
