Delete uploaded prompts and music?
Discussion in '3CX Phone System - General' started by zanthexter, Dec 4, 2017.
  1. zanthexter
    Jun 30, 2009
    11
    How do I delete uploaded prompts and music that will no longer be used?
    I'm using the Google Cloud version. I'm hoping there's a web page I'm overlooking and that I won't have to wander into the wilds of Linux land. ;)
    I DID try to RTFM, but couldn't locate the answer.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @zanthexter
    You can delete whole prompt sets from Management Console >> Settings >> System Prompts >> Manage Prompt Set, but for individual files you'll need to access your VM with SSH i'm afraid. Just CD to var/lib/3cxpbx/Instance1/Data/Ivr/Prompts and delete the .wav files that you want.
