Deliver Fax to Folder?
Discussion in '3CX Phone System - General' started by JCarnes, Jan 18, 2017.
  1. JCarnes
    Apr 25, 2016
    24
    Does 3CX provide any means to deliver an inbound fax to a folder (either directly on the local machine or to a network folder)? I see how we can send in inbound fax to an email or fax device, but I'm not seeing how to simply save the inbound fax to a folder. Is this doable at all?
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Dear JCarnes,
    Any received inbound Faxes are stored to the following path on Windows C:\ProgramData\3CX\Instance1\Data\Fax and on Linux
    /var/lib/3cxpbx/Instance1/Data/Fax (stored directly on the local machine). You can't change this option in order to save fax documents to a network folder. However you can write a bash script to make a copy of received documents folder to a network folder.
  3. JCarnes
    Apr 25, 2016
    24
    Thank you for the info. That is good to know and may at least help for now.
