Deliver VoiceMail to server
Discussion in '3CX Phone System - General' started by marmac, Jun 17, 2007.
  1. marmac
    Jun 17, 2007
    6
    This is my trouble....
    I never saw one email delivered from the PBX.
    I tried with the server of mine provider.
    I tried with the server of IIS in localhost (with error), 127.0.0.1 and 192.168.x.x
    I put port 25 and I removed it.
    I verified with telnet (it works)
    What can I do?
  2. marmac
    Jun 17, 2007
    6
    NOW the provider server WORK!
    I don't know why, but it seems work... This PBX work on WinXP-sp2 (the other one is a clone of this and it works on Win2k-sp4)
    If someone can explain me why the other cases does not works.
    I appreciate any reply.
  3. Anonymous
    Anonymous Guest
    For use with your service provider you most of the time enter mail.yourserviceprovider.com
    If your provider has SPF enabled you have to enter login details to the mail server this can not be done at the moment I believe.
    If you run an exchange server you can simply enter the ip address of the exchange server.
    If you do not run an exchange server make sure that you have your mail server installed on your box, the smtp bit.
